Monitoring Windows 2016 Scheduled Tasks
ClemClem
Post by ClemClem »
I'm trying to monitor if the task is done once a day.
I have this response:
/usr/local/nagios/libexec/check_nrpe -H server.domain.com -c check_tasksched -a "filter=title eq 'get_eurofxref'" 'critical=most_recent_run_time < 1,440' empty-state=critical 'empty-syntax=CRITICAL:get_eurofxref NOT found' 'detail-syntax=$${title} is stale more than 1,440'
Failed to validate filter see log for details
I'm pretty new to Nagios XI what can be wrong?
Re: Monitoring Windows 2016 Scheduled Tasks
What is the version of NSClient++ that you are currently using?
Can you upload the nsclient.ini and nsclient.log file on the forum?
ClemClem
Post by ClemClem »
nsclient (x64) 0.4.4.23
nsclinet.ini
# If you want to fill this file with all avalible options run the following command:
#   nscp settings --generate --add-defaults --load-all
#   nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/modules]
; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckDisk = 1
; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all.
CheckEventLog = 1
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 1
; Helper function - Various helper function to extend other checks. This is also only supported through NRPE.
CheckHelpers = 1
; Check NSCP - Checkes the state of the agent
CheckNSCP = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; CheckWMI - CheckWMI can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckWMI = 1
; NRPE server - A simple server that listens for incoming NRPE connection and handles them.
NRPEServer = 1
; NSClient server - A simple server that listens for incoming NSClient (check_nt) connection and handles them. Although NRPE is the preferred method NSClient is fully supported and can be used for simplicity or for compatibility.
NSClientServer = 1
; CheckTaskSched - Check status of your scheduled jobs.
CheckTaskSched = enabled
[/settings/NRPE/server]
; Undocumented key
insecure = true
; COMMAND ARGUMENT PROCESSING - This option determines whether or not the we will allow clients to specify arguments to commands that are executed.
allow arguments = true
; COMMAND ALLOW NASTY META CHARS - This option determines whether or not the we will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
allow nasty characters = true
; PORT NUMBER - Port to use for NRPE.
port = 5666
[/settings/logfile]
; DEBUG - Log more information to help diagnose errors and configuration problems.
debug = true
[/settings/default]
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = no tell to anyone
; Undocumented key
password = u wish to know
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = checkCPU warn=80 crit=90 time=5m time=1m time=30s
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = checkProcState "$ARG1$=started"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = checkProcState "$ARG1$=stopped"
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = checkServiceState CheckAll $ARG1$
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = checkUpTime MinWarn=1d MinWarn=1h
; alias_updates - Alias for alias_updates. To configure this item add a section called: /settings/external scripts/alias/alias_updates
alias_updates = check_updates -warning 0 -critical 0
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
; default - Alias for default. To configure this item add a section called: /settings/external scripts/alias/default
default =
[/settings/external scripts]
[/settings/external scripts/wrappings]
; BATCH FILE WRAPPING -
bat = scripts\\%SCRIPT% %ARGS%
; POWERSHELL WRAPPING -
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
; VISUAL BASIC WRAPPING -
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
check_smartarray = cscript.exe //T:30 //NoLogo scripts\\check_smartarray.vbs
; A set of filters to use in real-time mode
[/settings/eventlog/real-time/filters]
the log last entry
2019-12-24 12:23:46: error:c:\source\nscp\include\nrpe/server/protocol.hpp:80: Rejected connection from: 172.19.254.123
Try changing you command to this:
/usr/local/nagios/libexec/check_nrpe -H server.domain.com -c check_tasksched -a "filter=title eq 'get_eurofxref'" 'critical=most_recent_run_time < 1440m' empty-state=critical 'empty-syntax=CRITICAL:get_eurofxref NOT found' 'detail-syntax=$${title} is stale more than 1440m'
Note: Remove the "," and add a unit, e.g. "m" for minutes.
Is it working now?
ClemClem
Post by ClemClem »
Yes it works, the command is ok I change also < for >
[[email protected] ~]$ /usr/local/nagios/libexec/check_nrpe -H server.domian.com -c check_tasksched -a "filter=title eq 'get_eurofxref'" 'critical=most_recent_run_time > 1440m' empty-state=critical 'empty-syntax=CRITICAL:get_eurofxref NOT found' 'detail-syntax=$${title} is stale more than 1440m'
: All tasks are ok|'get_eurofxref_exit_code'=0;0;0 'get_eurofxref_most_recent_run_time'=1586844001;0;1586987452
but the service state is unknown state all the time
ClemClem
Post by ClemClem »
Service ->
ClemClem
Post by ClemClem »
Status ->
I don't know how the "CheckTaskSched" command is defined, so it is hard to say why it is failing.
However, what you should be using is:
Check command = check_nrpe
$ARG1$ = check_tasksched
$ARG2$ = -a "filter=title eq 'get_eurofxref'" 'critical=most_recent_run_time > 1440m' empty-state=critical 'empty-syntax=CRITICAL:get_eurofxref NOT found' 'detail-syntax=$${title} is stale more than 1440m'
Save, apply configuration.
Go to Home > Details > Service Status > Check Task get_eurofxref > Force an immediate check, and see if the error has been fixed.
ClemClem
Post by ClemClem »
I made the modification. When I run check command it's ok. I did save, apply and force.
The service state is still like in the previous post.
Can you PM me your latest profile (profile.zip)?
We will try to figure out what went wrong.
Admin > System Config > System Profile > Download Profile
