We currently have two servers in our log cluster that are running on CentOS 6. as 6 is EOL this year I am looking at spinning up 3 new CentOS 7 vm's.
My question is this. Would it be possible to add the 3 new servers to the existing cluster, and then retire the 2 original centOS 6 boxes?
I have not been able to find any specific documentation on this procedure.
Many thanks
New server install
Re: New server install
Yes. The only caveat is, when you have more than your licensed amount of instances in your cluster active, you will not be able to actively search logs.danniiffxi wrote:My question is this. Would it be possible to add the 3 new servers to the existing cluster, and then retire the 2 original centOS 6 boxes?
Depending on your cluster size, I would recommend adding one of the new CentOS 7 machines to the cluster, then removing one of the CentOS 6 machines, then wait until the cluster status shows Green (meaning there is a primary and replica of every shard in the indexes) and then repeat until all of the CentOS 6 machines are decommissioned.
danniiffxi
Excellent thank you Scott, we have an unlimited licence, so adding to the cluster should not cause any issues.
There is no such thing as an Unlimited Log Server license, except in a trialdanniiffxi wrote:Excellent thank you Scott, we have an unlimited licence, so adding to the cluster should not cause any issues.
danniiffxi
Hi Scott
Understood. I misread the licence screen. I was looking at - License Instance Usage: 3 / ∞
You can lock this one now
thanks for your help
License Type: Data Instance Based
Licensed Data Instances: 2
Current Data Instances: 3
License Instance Usage: 3 / ∞ Upgrade your License
Okdanniiffxi wrote:Hi Scott
You can lock this one nowCode: Select all
License Type: Data Instance Based Licensed Data Instances: 2 Current Data Instances: 3 License Instance Usage: 3 / ∞ Upgrade your Licensethanks for your help
Locking
