no uptime graph for custom alive check
katieKatiePants
helloooooo nagios universe. after having read [https://support.nagios.com/kb/article/n ... ems-9.html] and the other forum post from 2012 about uptime graphs from custom uptime checks, am a little stuck. what doco should i follow to build the right <thing> for the uptime graphs? i suspect i'm supposed to build an .xml file (?) or a template somewhere (?) ... is there a doco that i can follow? #superLost
Re: no uptime graph for custom alive check
FYI, if the plugin outputs performance data in the correct format, the XI system will automatically create the xml and rrd files and display the graph in the GUI.
If you can run the uptime check in a root shell and post the output so we can see what the plugin displays, we can see if it is the correct format to be graphed.
See this guide under the performance data section to see what it should look like.
https://nagios-plugins.org/doc/guidelines.html
The only thing that determines whether or not performance data is built is if the plugin returns it in the output.
See here:
If the service name used to have a different check command you may need to delete the old RRD so it gets rebuilt:
Please link us to the exact plugin you're using, make sure to check the help section of the plugin (if any) to look for performance data options.
Thank you
See here:
https://assets.nagios.com/downloads/nagioscore/docs/nagioscore/4/en/pluginapi.htmlCode: Select all
rm /usr/local/nagios/share/perfdata/HOSTNAME/SERVICENAME.rrdThank you
katieKatiePants
@ssax and @tgriep - thank you for the response, today is not a total waste of space and time.
for your curiosity, i'm using on the Super Evil Nagios port ... i'll get the outputs from your asks after this interminable call ends.
#I have one job on this ship, it's stupid, but i'm going to do it. -Tawny Madison#
check_tcp#I have one job on this ship, it's stupid, but i'm going to do it. -Tawny Madison#
Last edited by katieKatiePants on Thu Apr 16, 2020 4:41 pm, edited 1 time in total.
katieKatiePants
[root@ip-10-10-10-10 centos]# /usr/local/nagios/libexec/check_tcp 10.20.20.20 -H 10.20.20.20 -p 5693 20
TCP OK - 0.002 second response time on 10.51.0.10 port 5693|time=0.002101s;;;0.000000;10.000000
katieKatiePants
<a whole bunch of redacted profanity> ... just now looking at the template and found that the "process perf data" button was set to "screw you katie" mode ... hoping this "fixes" it.
Ahh, that'll do it. Are you seeing them show up now?
Send the output of these commands as well:
ls /usr/local/nagios/var/spool/perfdata/ | wc -l
ls /usr/local/nagios/var/spool/xidpe/ | wc -l-
katieKatiePants
so the output was 2 for each.
the graphs now say "no data to display" but now w/a time series axes so hoping that it'll start making pretty graphs starting "now"ish
wc -lthe graphs now say "no data to display" but now w/a time series axes so hoping that it'll start making pretty graphs starting "now"ish
That's correct, wait about 15 and let us know. Time plus multiple checks is what it needs.
katieKatiePants
looks like the _HOST_.rrd file hasn't been modified since the day when i brought it to life ... is that expected?
