check_eventlog scan range issue
shivangi
Post by shivangi »
Hi Team,
Check_eventlog is not accepting scan range .To be more exact i want alert if specfic eventid registering itself in last 2 min should raise alert , but when i am keeping scan range of -2m , it still showing warning alert for that specific id which is not registered in last 2 min but before that time and also removing the scan range option totally also does not affect the result .
What is the use of scan range then ? Not quite understanding this behaviour . Please help in this .
Thanks in advance .
cdienger
Re: check_eventlog scan range issue
Post by cdienger »
Are you using the check_eventlog plugin that is available with NSClient++?
https://docs.nsclient.org/reference/win ... kEventLog/
Make sure you're passsing the scan-range argument with the -a flag. For example:
./check_nrpe -H 192.168.55.5 -c check_eventlog -a "scan-range-2m"
shivangi
Post by shivangi »
Thankyou , Its working now .
Also can you also please let me know if there is a way not to mention the eventid to be monitored in the filter but getting the ID info . in the output message whenever the warning or error id is logged .
I have to monitor 100 eventids for 3 instances which is a bit of tedious task to define service defintion for each event id separately .
Also will monitoring so many eventids have cause a load on Nagios (if i go separately defining them ) ?? My current version is nagios core 4.4.1 and is a cloud instance m4.xlarge .
Thanks in advance :)
shivangi
Post by shivangi »
Hi Team,
Any suggestions on this please ?
