New servers getting socket timeout or connection refused.
gdolidze
Post by gdolidze »
We use to have 2 physical server that the alerts worked fine on.
Now they are fresh new vms.
I have installed the nagios agent on them and getting the following , I have deleted the old alerts and re added the server as well but same.
On one server.
connect to address 10.1.1.50 and port 12489: Connection refused
The other server
CRITICAL - Socket timeout
jbrunkow
Re: New servesr getting socket timeout or connection refused
Post by jbrunkow »
Forgive me if this is a bit basic, but have you checked whether the IP address and port matches between the XI server and host machine?
Which agent are you installing? If you link the document or web page, then I can follow along and try to determine what should be changed.
The linked document below is a good place to get started monitoring something new in Nagios XI.
https://assets.nagios.com/downloads/nag ... os-XI.pdf
gdolidze
Re: New servers getting socket timeout or connection refused
Post by gdolidze »
We use NSClient++ as the agent. The version is 0.4.4 (64bit)
I specified the host and password on the client side and the password on the nagios side.
jbrunkow
Post by jbrunkow »
It's likely a firewall issue. Is the NSClient service running and did you restart the service after specifying the host and password? If you cannot establish communication, please post the nsclient.ini file to the thread.
You can test if a port is accessible by using the nmap command from the Nagios XI server
nmap <windows machine address> -p T:12489
Thanks.
Reference
Configuring The Windows Agent: NSClient++
