Alert if a process IS running?
mbeebe
Post by mbeebe »
All,
Due to powers beyond my control, a certain unnameable organization within my company likes to play the role of Chaos Monkey and run processes on production servers, generally without warning anybody, that then cause said servers to crash at 3:00am. This leads to much wailing and gnashing of teeth, along with theological questions about how could a beneficent and all-seeing deity allow such things to happen without then smiting the perpetrators.
td;dr: is there a way to get an alert if a process IS running? This is on Linux and using SNMP.
-- Mike Beebe
jdunitz
Re: Alert if a process IS running?
Post by jdunitz »
I used to work somewhere where one of the admins considered "screen" a dangerous, nefarious tool, and wouldn't allow it on any system.
People would compile their own binaries and try to hide them, but eventually he'd notice.
If I were that guy, I'd be absolutely chuffed to find I could do this:
https://support.nagios.com/kb/article/p ... ss_running
[screen is terminating]
[root@jpd-nagiosxi-one libexec]#  ./check_procs -C screen -c 0
PROCS OK: 0 processes with command name 'screen' | procs=0;;0;0;
...then I start up a screen session, and:
PROCS CRITICAL: 2 processes with command name 'screen' | procs=2;;0;0;
Aha!!!
How's that?
--Jeffrey
mbeebe
Post by mbeebe »
Hey Jeffrey,
Thanks for the truly awesome response!
It wouldn't work in our case, because we need SNMP over NRPE, but I did manage to figure it out.
There's a super-awesome command called "negate", which tell a check to look for the OPPOSITE of what it's checking for:
./negate -s ./check_snmp_process_wizard.pl -H <hostname> -C <community string> -n <process name> -w 0 -c 0
This tells the check command to treat any result that would be an ALERT as an OK instead.
Wonderful discovery!
(go ahead and close thread. Thanks!)
-- Mike
jdunitz wrote:I used to work somewhere where one of the admins considered "screen" a dangerous, nefarious tool, and wouldn't allow it on any system.
Aha!!!
How's that?
--Jeffrey
ssax
Dreams In Code
Post by ssax »
This command will always return OK:
I thought you wanted to check for the procesname to see if it is running and alert you if it is? The command above won't do that.
