ERROR: deadlock detected
lgaddam
Post by lgaddam »
Hi Sean,
We are able to see continuous deadlocks created in Nagios.
Nagiosxi is not able to open while deadlocks available in postgres logs.
I have executed dbrepair script, deadlocks have lost, webconsole opening successfully.
But still deadlocks keep visiting ….what to do for this....
lgaddam
Re: ERROR: deadlock detected
Post by lgaddam »
Before DBrepair execution.
[root@p01 pg_log]# tail -f postgresql-Mon.log
DETAIL: Process 11728 waits for ShareLock on transaction 1853508055; blocked by process 14612.
Process 14612 waits for ShareLock on transaction 1853515079; blocked by process 11728.
LOG: unexpected EOF on client connection
DETAIL: Process 24188 waits for ShareLock on transaction 1853508055; blocked by process 14612.
Process 14612 waits for ShareLock on transaction 1853514025; blocked by process 24188.
DETAIL: Process 14612 waits for ShareLock on transaction 1853513647; blocked by process 29952.
Process 29952 waits for ShareLock on transaction 1853508055; blocked by process 14612.
DETAIL: Process 26001 waits for ShareLock on transaction 1853513647; blocked by process 29952.
Process 29952 waits for ShareLock on transaction 1853510138; blocked by process 26001.
DETAIL: Process 29952 waits for ShareLock on transaction 1853511484; blocked by process 29693.
Process 29693 waits for ShareLock on transaction 1853513647; blocked by process 29952.
DETAIL: Process 29693 waits for ShareLock on transaction 1853515212; blocked by process 6744.
Process 6744 waits for ShareLock on transaction 1853511484; blocked by process 29693.
DETAIL: Process 24584 waits for ExclusiveLock on tuple (195,53) of relation 145442 of database 16385; blocked by process 31034.
Process 31034 waits for ShareLock on transaction 1853508396; blocked by process 24079.
Process 24079 waits for ShareLock on transaction 1853515212; blocked by process 6744.
Process 6744 waits for ExclusiveLock on tuple (195,53) of relation 145442 of database 1
After DBrepair execution.
DETAIL: Process 9956 waits for ShareLock on transaction 1854514081; blocked by process 23882.
Process 23882 waits for ShareLock on transaction 1854514075; blocked by process 9956.
How to provide attachments privately here without disclosing to public ?
benjaminsmith
Post by benjaminsmith »
How to provide attachments privately here without disclosing to public?
You can send them over in a PM or alternatively you can open a support ticket for the issue.
Since you are running Postgres, did run a vaccum on the database? You'll find the commands for you distro available on the kb article below.
https://support.nagios.com/kb/article.p ... POSTGRESQL
After that, let the system run and send over a fresh copy of the system profile, if the issue persists.
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
