Upgrade from 2.0.8 giving multiple PHP errors
ikotcher
Post by ikotcher »
Upgrade script throwing multiple errors below:
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib64/php/modules/ixed.5.4.lin' - /usr/lib64/php/modules/ixed.5.4.lin: undefined symbol: zend_get_hash_value in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library '/usr/lib64/php/modules/ixed.5.6ts.lin' - /usr/lib64/php/modules/ixed.5.6ts.lin: undefined symbol: core_globals_id in Unknown on line 0
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.6.lin
Sourceguardian extension found for PHP version 5.6
Sourceguardian extension already in php.ini
Connection timed out after 15001 milliseconds
PHP Fatal error: Call to undefined function simplexml_load_string() in /var/www/html/nagioslogserver/application/helpers/licensing_helper.php on line 0
What is going on here? I have placed these loaders in the relevant directory, dropped them into php.ini, and restarted httpd but still get same error.
Ivan Kotcher
Principal Consultant
+1.817.917.3003 (mobile)
[email protected]
cdienger
Re: Upgrade from 2.0.8 giving multiple PHP errors
Post by cdienger »
Please provide the upgrade.log as well as a copy of the /etc/php.ini.
You should only need one loader and it should match the php version on the system. Verify the php version:
php -v
and the permissions of the modules:
ll /usr/lib64/php/modules/
