I'm having a weird behaviour under Nagios 3.3.1. When I specify some filters to status.cgi, I don't see any alarm on the screen but I get the audible alarm. I'm passing these variables to it. Any tip?
this is the argument I use on status.cgi:
status.cgi?hostgroup=all&style=detail&hostprops=270378&hoststatustypes=4&serviceprops=270378&servicestatustypes=16
(this is what I want to see)
Host Status Types: Down
Host Properties: Not In Scheduled Downtime & Has Not Been Acknowledged & Checks Enabled & Notifications Enabled & In Hard State
Service Status Types: Critical
Service Properties: Not In Scheduled Downtime & Has Not Been Acknowledged & Active Checks Enabled & Notifications Enabled & In Hard State
thanks in advance
Alarm sounds playing without any alarm listed on status.cgi
Re: Alarm sounds playing without any alarm listed on status.
I'm not sure I follow. Can you post a screenshot of what you expect to see from a page with no filters?
Without any filters: (all hosts and services listed)
http://cl.ly/0T0Z253M0k0b1C3J0H10
With filters (the intention is to list: Hosts Down, Critical States; Hard State; NOT in schedule downtime and NOT acknowledge)
http://cl.ly/1W3y0F3F3Y0W1r0l0G1J
Additional notes:
I've installed another instance of Nagios, this time 3.4.1 without the exfoltiation theme and I get the same results.
The critical sound is played every time I refresh the page and I've 0 matching results for the used display filter query.
http://XXX/SOFIA2/nagios/cgi-bin/status ... ops=393226
Display Filters:
Host Properties: Not In Scheduled Downtime & Has Not Been Acknowledged & Active Checks & In Hard State
Service Properties: Not In Scheduled Downtime & Has Not Been Acknowledged & Active Checks & In Hard State
Additional notes:
Display Filters:
Ah, so the issue is that you're hearing audio alerts for services which do not match the filter. Unfortunately, I think is the expected behavior and I don't think you're going to be able to get what you want without modifying Nagios itself.
ups.. it's sad to listen that
many thanks for your fast reply.
Sorry about that, hope you can come up with a setup you like.
