I installed Nagios Core 4.4.5 on RHEL 8 and I´m encountering several problems that I detail below:
The plugin check_vmware_api.pl does not work correctly, because Crypt :: SSLeay does not install
Integrating Nagios with Grafana, using php 7.2, Nagflux and Histou, it shows an error HTTP code: 404
is there incompatibility?
Regards
Install Nagios Core + Grafana in RHEl 8
benjaminsmith
Re: Install Nagios Core + Grafana in RHEl 8
By the way, we haven't rolled out official RHEL 8 support yet on any of our products. However, it's coming soon!
It's possible that the package may not be available yet in the base repo. What specific error message do you get?I installed Nagios Core 4.4.5 on RHEL 8 and I´m encountering several problems that I detail below:
