Hello Team,
We have found some discrepancies between the executable path of NSC++ service and other services.
When we check NSC++ properties in "Services" on Windows server, the executable path is without double quotes.
But, when we check any other service properties in "Services" on the same Windows server, the executable path is within double quotes.
I am attaching the screenshot for your reference.
Is there a way to make the path appear in double quotes?
Please suggest!!
Nagios service path configuration to be modified
Thanks & Regards,
I2MP Team.
I2MP Team.
Re: Nagios service path configuration to be modified
Please note that NSClient++ is not our project so this is bit beyond our scope, but it looks like it can be done with an edit to the registry. Just type 'change path to executable' into your favorite search engine and you should find the steps to make the change.
Thanks for your help!!
We checked Registry editor and it worked fine, we can close this thread
Thanks & Regards,
I2MP Team.
I2MP Team.
Great!RIDS_I2MP wrote:Hello,
Locking
