HEy,
i was wondering if there is a way to get an average data on the cpu load/usage of all the servers i am currently monitoring, is there a tool in place to pull this information?
get average cpu load for all servers monitored
benjaminsmith
Re: get average cpu load for all servers monitored
Hello @rnjie,
On option is to download the performance graph data (for example, CPU Usage for the "Last 365 Days") as CSV. This is done on a "per host/service" basis. Currently, there's not a way to aggregate this data. but this could be a new feature request.
Also, the metrics component, Home > Details > Metrics, will provide a summary table in a dashlet that can be cut and pasted into Excel for averaging.
I hope that helps. Let me know if you have any questions.
thank you, that was so helpful
one last question, i did the metric solution and it gave me the report but i couldn't tell the time period it generated it from, i know there is an option to choose the time period from the graph section, does that also apply to the summary?
benjaminsmith
Hello @rnjie,
You're most welcome! After digging in further on those results, it's the last check result and not aggregated over time.
Let me know if you any other questions. I can certainly submit a feature request on your behalf to the development team if you'd like.
Benjamin
Benjamin
thanks, please close the case
benjaminsmith
Excellent! Thank you for using Nagios.thanks, please close the case
Benjamin
