I am trying out Nagios before going to the commercial version. We are a fortune 50 company from India and want to use Nagios.
However i have a problem with this Plugin called interfacetable_v3t. I have used the latest version of 1.0.
But in the Nagios dashboard - get this error message - (No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_interface_table_v3t, ...) failed. errno is 2: No such file or directory
1. I have made sure that the check_interface_table_v3t is in the /usr/local/nagios/libexec/
2. the permissions are -
libexec]# ls -l check_interface_table_v3t.pl
-rwxr-xr-x 1 nagios nagios 481741 Apr 26 22:48 check_interface_table_v3t.pl
3. If i go to the URL - http://10.209.184.19/interfacetable_v3t/tables/ i see data
The idea is that i want to load this plugin from Nagios.
Here is the script that i am running -
check_command INTERFACES!public!2!f
command_line $USER1$/check_interface_table_v3t -H $HOSTADDRESS$ -C -$ARG1$ -$ARG2$
checked this way too -
check_command INTERFACES!public!-2!-f
command_line $USER1$/check_interface_table_v3t -H $HOSTADDRESS$ -C $ARG1$ $ARG2$ $ARG3$
Nagios plugins - interfacetable_v3t issues
Re: Nagios plugins - interfacetable_v3t issues
Please help, i see that 28 views to this topic but no answer. Hope to get answers for this since i need to present to management if we need to go for support based Nagios or go to a different network management system. I am with a company called Wiprobadri2830 wrote:Hello,
