Hello Team,
We have a requirement of Monitoring Android apps and apps hosted on Citrix? and also VDI's. Can we do this with NagiosXI?
If so, how do we do this?
Regards,
Beena
Android Apps monitoring on NagiosXI
Re: Android Apps monitoring on NagiosXI
I'm not aware of any agents available for Android. For the Citrix apps, you may find something on the exchange: exchange.nagios.com, or depending on what you want to monitor exactly the NCPA agent and check_http plugin may give you what you want: http://www.nagios.com/ncpa & https://assets.nagios.com/downloads/nag ... ios-XI.pdf. For VDIs I would check the NCPA agent as well as the VMWARE wizard: https://library.nagios.com/library/prod ... nagios-xi/.
