Time to run a command in Nagios Core
phamcong96hy
Post by phamcong96hy »
I am installing Nagios Core 4.3.2 on Centos 8. When I write a plugin /usr/local/nagios/libexec/check_defacement.sh set in tor and curl. in the check_defacement.sh file, there is a segment:
service tor start
curl -s --socks5-hotsname 127.0.0.1:9050 - $url > /tmp/check_defacement_ $url
service tor stop
When I run the command directly, it returns the file /tmp/check_defacement_ $ url. But when I ran through nagios with command.cfg and object.cfg, it returned file empty /tmp/check_defacement_ $url.
jdunitz
Re: Time to run a command in Nagios Core
Post by jdunitz »
Hi Pham,
How is $url getting passed to the script? Most likely, there's something in how you're doing that that's getting lost when Nagios runs it.
Can you post your commands.cfg and object.cfg, or at least the important pieces of those files?
Be sure to remove or obscure any sensitive information.
We'll have a look at your configs and see what might be wrong; it might be that how you're calling the script from within commands.cfg isn't quite right.
--Jeffrey
