Nagios4 prompts for pass but has limited capabilities
jordanthompson
Post by jordanthompson »
I followed the instructions from here:
https://support.nagios.com/forum/viewto ... =7&t=56970
And now nagios prompts me to log in.
It is correctly parsing the username/password.
Unfortunately, I cannot access some functions and I get this error:
It appears as though you do not have permission to view information for any of the hosts you requested...
Here is my apache2.conf file:
listen 8080
<VirtualHost *:8080>
ScriptAlias /cgi-bin/nagios4 /usr/lib/cgi-bin/nagios4
ScriptAlias /nagios4/cgi-bin /usr/lib/cgi-bin/nagios4
Alias /nagios4/stylesheets /etc/nagios4/stylesheets
Alias /nagios4 /usr/share/nagios4/htdocs
<Directory /usr/share/nagios4/htdocs>
    Options     +ExecCGI
    #  SSLRequireSSL
    Options None
    AllowOverride None
    <RequireAll>
         Require all granted
         AuthName "Nagios Access"
         AuthType Basic
         AuthUserFile /etc/nagios4/htdigest.users
         Require valid-user
    </RequireAll>
</Directory>
<DirectoryMatch (/usr/lib/cgi-bin/nagios4|/etc/nagios4/stylesheets)>
    Options FollowSymLinks
    DirectoryIndex index.php index.html
    AllowOverride AuthConfig
    Require ip	::1/128 fc00::/7 fe80::/10 10.0.0.0/8 127.0.0.0/8 169.254.0.0/16 172.16.0.0/12 192.168.0.0/16 10.13.0.0/8
    <Files "cmd.cgi">
 	AuthDigestDomain "Nagios4"
 	AuthDigestProvider file
 	AuthUserFile	"/etc/nagios4/htdigest.users"
 	AuthGroupFile	"/etc/group"
 	AuthName	"Nagios4"
 	#AuthType	Digest
 	AuthType	Basic
 	#Require all	granted
 	Require	valid-user
    </Files>
</DirectoryMatch>
#<Directory /usr/share/nagios4/htdocs>
#    Options	+ExecCGI
#</Directory>
</VirtualHost>
I would appreciate any suggestions anyone may have!
jordanthompson
Re: Nagios4 prompts for pass but has limited capabilities
I am still stuck here. If I could completely disable the login that would be fine. This is just a home server inside a firewall with limited access.
thanks in advance
