how to remove service check from Monitoring
Pratapa
Post by Pratapa »
We need to remove service check "Swap" on one of the hosts.
But this service check has come by default upon configuring the host.
We are using Nagios core.
benjaminsmith
Re: how to remove service check from Monitoring
Post by benjaminsmith »
Hi Pratapa,
Not exactly sure how you have the templates and configurations set, but if you can't delete the service, one option is to leave it there and disable checks in the object definition.
active_checks_enabled	0
passive_checks_enabled	0
I hope that helps.
