nagios core server behind proxy
chand5584
Post by chand5584 »
i have installed nagios core server (ubuntu 16.04) behind a proxy. To reach the internet from the machine where i have deployed nagios server, I use proxy settings in the environment. How to make check_http to reach public URL using the proxy. Similarly, i need to reach DNS server also. How do i make Nagios core server use proxy,dns.
please suggest.
jdunitz
Re: nagios core server behind proxy
Post by jdunitz »
The check_http plugin supports proxying, as long as the proxy does basic auth (not NTLM):
./check_http -I myproxy.mydomain.com -p 8080 -S -j CONNECT -H www.google.com -u https://www.google.com/ -b myusername:mypassword -w 1 -c 5 -v
Hope that helps!
--Jeffrey
chand5584
Post by chand5584 »
I appreciate your help, Jeffrey.
It seems to be working for www.google.com working through proxy..But i have some applications deployed on the public that endpoint URL is with the port as given below. how to reach the below url using a proxy...i am unsure when we have applications with the port number.
example:
http://c0shopapi.westus.cloudapp.azure.com:5102
chand5584
Post by chand5584 »
t@ubuntu-tt:/usr/local/nagios/libexec# ./check_http -I 172.16.0.250 -p 8080 -j CONNECT -H http://c0shopapi.westus.cloudapp.azure.com -u http://c0shopapi.westus.cloudapp.azure.com:5102
connect to address 172.16.0.250 and port 0: Connection refused
HTTP CRITICAL - Unable to open TCP socket
root@ubuntu-tt:/usr/local/nagios/libexec#
how do i pass if my app is having port number in the endpoint.
