Network config issues in OVA image
remedsys
Post by remedsys »
I recently downloaded and installed the latest OVA image of NagiosXI on one of our ESXi hosts. I tried to add a second NIC to the server in order to monitor some hardware on our storage network, and now I cannot get the network interface to come back up.
Originally NagiosXI was grabbing an IP from our DHCP server, but now it won't, even if I set it to DHCP. When I try to set a static IP, I'm also unable to access the server.
I've tried removing and re-adding the NIC in vSphere, but that did nothing.
When I try to ifup <interface> I get the following:
Error: Connection activation failed: IP configuration could not be reserved (no available address, timeout, etc.)
I've attached a screenshot of the config from /etc/sysconfig/network-scripts
Re: Network config issues in OVA image
This doesn't seem like a nagios issue... What is the IP address that you are using, when trying to access Nagios XI? What is the output of the commands below?
service network restart
ip addr
You may try to comment out the old entries in /lib/udev/rules.d/75-persistent-net-generator.rules and/or /etc/udev/rules.d/70-persistent-net.rules and restart the VM to see if this is going to fix the issue.
