DB Connect Error
super_marino
DB Connect Error
Post by super_marino »
This morning, I logged into NagiosXI on the web interface and received the following error:
DB Connect Error [nagiosxi]: Database connection failed.
I did a search through the forum and found this thread:
http://support.nagios.com/forum/viewtop ... ror#p25583
I looked through the solution however when I tried to issue the first command in that thread I get an error at the CLI of Nagios.
Command = psql nagiosxi nagiosxi -c 'vacuum;'
Error =
sd 0:0:0:0: rejecting I/O to offline device
-bash: /usr/bin/psql: Input/output error
Then even without any commands being entered I continually receive this error:
I'm not a Linux expert, but it looks like the primary drive is unmounted?
With all the strange issues I've been having, it looks like this image or install of nagios might be a lemon.
Any help would be appreciated....
Super_Marino
mguthrie
Re: DB Connect Error
Post by mguthrie »
Can you post the output from:
df -h
super_marino
mguthrie,
Unfortunately the system (linux) won't even let me issue this command without throwing me an error.
Same as before.
Would you suggest I restart this system?
FYI:
- Running on a Hyper-V Server
- Latest Nagios (Virtual PC vhd image) with Updates
mguthrie
Post by mguthrie »
Most definitely yes : )
super_marino
Hi mguthrie,
Seems like after a HARD RESET, the system started working again.
I ran the repairmysql for nagios and nagiosql just to repair any corrupt portions of the DB.
Hopefully this doesn't happen again.
Any suggestions beyond this?
This seems like for some reason your VM wasn't able to connect to it's storage on the Hyper-V Server server.. At the very least it is strange.
Sounds like you did the necessary steps for the database.
Only thing I would add is if you have any other similar issues, I would look at possible problems with the Hyper-V Server's storage.
Also, while you have it running it would be prudent to make a backup of your XI install and move it offsite in case another problem arises
http://library.nagios.com/library/produ ... -nagios-xi
