Hi Guys
I have a question.
With NCPA you have to code the 'mytoken' in your services.cfg file right, Is there a way to encrypt this token as it is clear text in a file?
Is this not a security concern having a "password" in clear text?
NCPA - mytoken encryption
Re: NCPA - mytoken encryption
We put it in .../private/resource.cfg in a "USER-variable" higher then 10 (in the default configuration, "USER-variables" with an index of 10 or higher are "masked" in the CGI-output.
We have it like this:
In /etc/nagios/private/resource.cfg:
and then in /etc/nagios/objects/commands.cfg:
and last but not least in the service definition:
We are using the same token for multiple hosts, but have different tokens ($USER11$, $USER12$, ...) for different groups of hosts.
# NCPA Token
$USER10$=<hostgroup-1 secret token>
$USER11$=<hostgroup-2 secret token>Code: Select all
# 'check_ncpa' command definition
command_name check_ncpa
command_line $USER1$/contrib/check_ncpa.py -H $HOSTADDRESS$ -t $ARG1$ -M '$ARG2$' $ARG3$
}Code: Select all
use local-service,srv-pnp
service_description Memory Usage
host_name iddjo03
check_command check_ncpa!$USER10$!memory/virtual
D/\N
D/\N
