Nagios Fusion Host Group Dashlet
All,
I have a host group with 1,452 hosts and the dashlet is dropping the 4th digit...showing 452. I have deleted and re-added with the same results of 3 digits? I can view the same host group on the Nagios XI server and it shows the correct number of 1,452. Am i missing something...
Re: Nagios Fusion Host Group Dashlet
I labbed this up and it's working properly on mine. What version of Fusion are you running?
Try running this command and then waiting 15 minutes for the data to rebuild:
Then logout of your account in Fusion, then re-login again.
/usr/local/nagiosfusion/scripts/truncate_polled.phpRe: Nagios Fusion Host Group Dashlet
Thanks for your reply...I tried the command and waited 15 minutes and have the same result. I am on version 4.1.7 for Fusion and 5.6.6 for Nagios XI.
In your lab did you create a host group that had over 1,400 hosts? The dashlet works fine on host counts under 4 digits for me.
Yes, I created 1850 hosts and added them to a single hostgroup, the number showed properly.
Do this, run this command as root on the fusion server and leave it running:
Then open the page that shows that dashlet and once it loads send us the full output of the still running tail command.
tail -Fn0 /var/log/httpd/error_log /var/log/httpd/ssl_error_logRe: Nagios Fusion Host Group Dashlet
[root@lnxvnaghq004 scripts]# tail -Fn0 /var/log/httpd/error_log /var/log/httpd/ssl_error_log
==> /var/log/httpd/error_log <==
==> /var/log/httpd/ssl_error_log <==
[Tue May 05 16:22:34.169864 2020] [:error] [pid 29307] [client 10.13.163.30:54088] PHP Notice: Undefined index: auth_token in /usr/local/nagiosfusion/html/includes/components/fusioncore/fusioncore.inc.php on line 239, referer: https://lnxvnaghq004.cinfin.com/nagiosf ... ervers.php
[Tue May 05 16:22:41.956342 2020] [:error] [pid 30215] [client 10.13.163.30:54091] PHP Notice: Undefined index: auth_token in /usr/local/nagiosfusion/html/includes/components/fusioncore/fusioncore.inc.php on line 239, referer: https://lnxvnaghq004.cinfin.com/nagiosfusion/
I clicked on Home and then I tried to refresh the screen. This is all of the output.
Is the user you logged into the Fusion web interface as an Admin on that XI server?
Please attach this file:
/usr/local/nagiosfusion/html/includes/dashlets/hostgroup_summary/hostgroup_summary.phpRe: Nagios Fusion Host Group Dashlet
Yes - admin level id accessing.
File below:
File below:
[root@lnxvnaghq004 ~]# cat /usr/local/nagiosfusion/html/includes/dashlets/hostgroup_summary/hostgroup_summary.php
<?php
require_once(dirname(__FILE__) . '/../dashlet-helper.inc.php');
dashlets_data_check();
hostgroup_summary_dashlet();
function hostgroup_summary_dashlet() {
$server = grab_request_var('server');
$hostgroup = grab_request_var('hostgroup', 0);
$server = get_server($server);
if ($server === false) {
echo '<h3>' . _('Invalid server selection!') . '</h3>';
exit();
$hostgroup_members = get_server_polled_key($server, 'hostgroup_members', $limit = 1);
$host_status = get_server_polled_key($server, 'host_status', $limit = 1);
$service_status = get_server_polled_key($server, 'service_status', $limit = 1);
if (!isset($hostgroup_members[0]['hostgroup_members'])) {
echo '<h3>' . _('No recent data found for specified server!') . '</h3>';
exit();
$polled_time = date('Y-m-d H:i:s', $hostgroup_members[0]['polled_time']);
$polled_time = convert_server_timestring_to_local_timestring($server, $polled_time);
$hostgroup_members = unpack_array($hostgroup_members[0]['hostgroup_members']);
$host_status = unpack_array($host_status[0]['host_status']);
$service_status = unpack_array($service_status[0]['service_status']);
if (!isset($hostgroup_members[$hostgroup])) {
echo '<h3>' . _('No hostgroup data found!') . '</h3>';
exit();
$host_counts = array(
STATE_UP => 0,
STATE_DOWN => 0,
STATE_UNREACHABLE => 0
$service_counts = array(
STATE_OK => 0,
STATE_WARNING => 0,
STATE_CRITICAL => 0,
STATE_UNKNOWN => 0,
$members = $hostgroup_members[$hostgroup]['members'];
if (is_array($members) && count($members) > 0) {
foreach ($members as $host_name) {
if (isset($host_status[$host_name])) {
$host = $host_status[$host_name];
$host_counts[$host['current_state']]++;
if (isset($service_status[$host_name])) {
foreach ($service_status[$host_name] as $service) {
$service_counts[$service['current_state']]++;
$host_output = '';
$service_output = '';
if (array_sum($host_counts) == 0) {
$host_output = '0 ' . _('hosts');
} else {
foreach ($host_counts as $state => $value) {
$class = $verb = '';
$link_xi = $link_core = '';
$noun = _('hosts');
if ($value == 1)
$noun = _('host');
switch ($state) {
case STATE_UP:
$class = 'hostup';
$verb = _('up');
$link_xi = 'includes/components/xicore/status.php?show=hosts&hostgroup=' . urlencode($hostgroup) . '&hoststatustypes=2';
$link_core = 'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=hostdetail&&hoststatustypes=2&hostprops=0';
break;
case STATE_DOWN:
$class = 'hostdown';
$verb = _('down');
$link_xi = 'includes/components/xicore/status.php?show=hosts&hostgroup=' . urlencode($hostgroup) . '&hoststatustypes=4';
$link_core = 'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=hostdetail&hoststatustypes=4&hostprops=0';
break;
case STATE_UNREACHABLE:
$class = 'hostunreachable';
$verb = _('unreachable');
$link_xi = 'includes/components/xicore/status.php?show=hosts&hostgroup=' . urlencode($hostgroup) . '&hoststatustypes=8';
$link_core = 'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=hostdetail&hoststatustypes=8&hostprops=0';
break;
if ($value > 0) {
$host_value = "{$value} {$noun} {$verb}";
$host_link = get_tactical_link($host_value, $server, $link_xi, $link_core);
$host_output .= "<div class=\"{$class}\">{$host_link}</div>";
if (array_sum($service_counts) == 0) {
$service_output = '0 ' . _('services');
} else {
foreach ($service_counts as $state => $value) {
$noun = _('services');
if ($value == 1)
$noun = _('service');
switch ($state) {
case STATE_OK:
$class = 'serviceok';
$verb = _('ok');
$link_xi = 'includes/components/xicore/status.php?show=services&hostgroup=' . urlencode($hostgroup) . '&servicestatustypes=2';
$link_core = 'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=detail&&servicestatustypes=2&hoststatustypes=15&serviceprops=0&hostprops=0';
break;
case STATE_WARNING:
$class = 'servicewarning';
$verb = _('warning');
$link_xi = 'includes/components/xicore/status.php?show=services&hostgroup=' . urlencode($hostgroup) . '&servicestatustypes=4';
$link_core = 'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=detail&servicestatustypes=4&hoststatustypes=15&serviceprops=0&hostprops=0';
break;
case STATE_CRITICAL:
$class = 'servicecritical';
$verb = _('critical');
$link_xi = 'includes/components/xicore/status.php?show=services&hostgroup=' . urlencode($hostgroup) . '&servicestatustypes=16';
$link_core = 'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=detail&servicestatustypes=16&hoststatustypes=15&serviceprops=0&hostprops=0';
break;
case STATE_UNKNOWN:
$class = 'serviceunknown';
$verb = _('unknown');
$link_xi = 'includes/components/xicore/status.php?show=services&hostgroup=' . urlencode($hostgroup) . '&servicestatustypes=8';
$link_core = 'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=detail&servicestatustypes=8&hoststatustypes=15&serviceprops=0&hostprops=0';
break;
if ($value > 0) {
$service_value = "{$value} {$noun} {$verb}";
$service_link = get_tactical_link($service_value, $server, $link_xi, $link_core);
$service_output .= "<div class=\"{$class}\">{$service_link}</div>";
$hostgroup = get_tactical_link($hostgroup, $server,
'includes/components/xicore/status.php?show=services&hostgroup=' . urlencode($hostgroup),
'status.cgi?hostgroup=' . urlencode($hostgroup) . '&style=overview');
<table class="table table-condensed table-striped table-bordered hoststatustable servicestatustable tactical">
<tr>
<th>
<?php echo _('Hostgroup'); ?>
</th>
<th>
<?php echo _('Hosts'); ?>
</th>
<th>
<?php echo _('Services'); ?>
</th>
</tr>
<tr>
<td>
<?php echo $hostgroup; ?>
</td>
<td>
<?php echo $host_output; ?>
</td>
<td>
<?php echo $service_output; ?>
</td>
</tr>
</table>
<?phpRe: Nagios Fusion Host Group Dashlet
Same as mine, I think we'll need to debug this on a remote session as the tables are pretty big.
Please create a ticket for this and include a link back to this forum thread so we can get a remote session setup:
https://support.nagios.com/tickets/
Created - Thanks for your help and looking forward to getting to the root of this.
Ticket info:
Fusion Dashlet Not Reporting 4 digits of host data #278014
Ticket info:
Great
Locking forum thread, moving to ticket
