Nagios Trap Receiver - VIP/Load Balancer
veeravamsi
Post by veeravamsi »
Hi Team,
Is it possible to have multiple Nagios Instances enabled to function as Trap Receiver in a Load-Balanced Way ??
Like Creating a VIP on Loadbalancer and add Nagios IPAddress:162 to redirect SNMP Traps incoming.
I couldnt find any documentation online so checking here.
--Vamsi
ssax
Dreams In Code
Re: Nagios Trap Receiver - VIP/Load Balancer
Post by ssax »
There is no inherent load balancing functionality built in for this.
It's not really load balancing but you could edit your /etc/snmp/snmptrapd.conf on each nagios server and add this:
Nagios A's snmptrapd.conf:
forward default NAGIOSBIP:162
Nagios B's snmptrapd.conf:
forward default NAGIOSAIP:162
Don't forget to restart the snmptrapd service on both:
service snmptrapd restart
That way every trap one receives would be forwarded to the other as well.
veeravamsi
Nice !! Does this help in Discarding the Traps on that Nagios Instance A where Host is not monitored ?
And accept only on Nagios Instance B where Host exists ?
ssax
Dreams In Code
Post by ssax »
Unfortunately, it doesn't discard the traps, it's just a way to forward the traps to another system.
You could technically do it by sending to the VIP and it should hit either server based on which node is active.
veeravamsi
Cool . thank you !
veeravamsi wrote:Cool . thank you !
Can we lock this thread?
veeravamsi
Yes please .
veeravamsi wrote:Yes please .
Great!
Locking thread
