check_drivesize issue again
rajasegar
Post by rajasegar »
Old thread
https://support.nagios.com/forum/viewto ... 16&t=53665
There is a new issue now.
I have a server where there is drive C & E. Individual checks works fine
[nagios@nagiosprodxi1 services]$  /usr/local/nagios/libexec/check_nrpe -u -t 60 -H 10.104.19.120 -p 5666 -c check_drivesize -a
 warn=used>=70' 'crit=used>=85' 'drive=C'        OK All 1 drive(s) are ok|'C: used'=94.68646GB;105.00068;127.50082;0;150.00097 'C: used %'=63%;70;85;0;100
[nagios@nagiosprodxi1 services]$  /usr/local/nagios/libexec/check_nrpe -u -t 60 -H 10.104.19.120 -p 5666 -c check_drivesize -a 'warn=used>=70' 'crit=used>=85' 'drive=D'
Filter processing failed: Failed to get size for D:: 3: The system cannot find the path specified.
: 0 >= convert(0)
[nagios@nagiosprodxi1 services]$  /usr/local/nagios/libexec/check_nrpe -u -t 60 -H 10.104.19.120 -p 5666 -c check_drivesize -a 'warn=used>=70' 'crit=used>=85' 'drive=E'
OK All 1 drive(s) are ok|'E: used'=66.88811GB;155.30634;188.58627;0;221.8662 'E: used %'=30%;70;85;0;100
However if I use drive =* it bombs
[nagios@nagiosprodxi1 services]$  /usr/local/nagios/libexec/check_nrpe -u -t 60 -H 10.104.19.120 -p 5666 -c check_drivesize -a 'warn=used>=70' 'crit=used>=85' 'drive=*' "filter=drive_or_id not like 'Volume' and type not in ('CDROM', 'REMOVABLE')"
CHECK_NRPE: Invalid packet type received from server.
Is there a way to get this to work? I think it is checking drive D and exits with error.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
ssax
Dreams In Code
Re: check_drivesize issue again
Post by ssax »
If you restart the nsclient service, does it fix it?
Please enable trace logging in your nsclient.ini, make the check fail again, and then attach (or PM) your nsclient.log for us to review.
; LOG SECTION - Configure log properties.
[/settings/log]
; DATEMASK - The size of the buffer to use when getting messages this affects the speed and maximum size of messages you can recieve.
date format = %Y-%m-%d %H:%M:%S
; LOG LEVEL - Log level to use. Available levels are error,warning,info,debug,trace
level = trace
; FILENAME - The file to write log data to. Set this to none to disable log to file.
file name = ${exe-path}/nsclient.log
Thank you
rajasegar
Post by rajasegar »
ssax wrote:If you restart the nsclient service, does it fix it?
[/settings/log]
level = trace
Thank you
Restart no luck. Trace attached but I dont see any useful info in there
nsclient.log
RHEL 6 & 7
ssax
Dreams In Code
Post by ssax »
Does it work if you don't use the filter?
rajasegar
Post by rajasegar »
ssax wrote:Does it work if you don't use the filter?
Still does not work
[nagios@nagiosprodxi1 ~]$ /usr/local/nagios/libexec/check_nrpe -u -t 60 -H 10.104.19.120 -p 5666 -c check_drivesize -a 'warn=used>=70' 'crit=used>=85' 'drive=*'
RHEL 6 & 7
ssax
Dreams In Code
Post by ssax »
I tested on mine with the latest and it's working properly.
Was this a drive that was removed while the system was running? Maybe it still sees it but can't get the statistics on it.
Does it work if you do this?
/usr/local/nagios/libexec/check_nrpe -u -t 60 -H 10.104.19.120 -P 8192 -p 5666 -c check_drivesize -a 'warn=used>=70' 'crit=used>=85'
Can you try upgrading to the latest on the system and test again?
https://nsclient.org/download/
rajasegar
Post by rajasegar »
ssax wrote:I tested on mine with the latest and it's working properly.
[nagios@MYUCBPNAGIAPP01 ~]$ /usr/local/nagios/libexec/check_nrpe -2 -u -t 60 -H 10.104.19.120 -P 8192 -p 5666 -c check_drivesize -a 'warn=used>=70' 'crit=used>=85'
CHECK_NRPE: Receive underflow - only 1026 bytes received (4 expected).
BTW we are already using 0.5.2.39 the latest. Last update was in 2018. Is NSClient++ not updated anymore?
You want me to try the nightly builds?
RHEL 6 & 7
ssax
Dreams In Code
Post by ssax »
No, that's correct, they don't update it often but they do work on it. We don't control that because we don't develop that agent (NCPA is our client).
Does this work by chance?
/usr/local/nagios/libexec/check_nrpe -2 -u -t 60 -H 10.104.19.120 -P 1026 -p 5666 -c check_drivesize -a 'warn=used>=70' 'crit=used>=85'
Please attach (or PM) your latest nsclient.ini so that I can lab it up with yours.
rajasegar
Post by rajasegar »
ssax wrote:No, that's correct, they don't update it often but they do work on it. We don't control that because we don't develop that agent (NCPA is our client).
CHECK_NRPE: Response packet had invalid CRC32.
nsclient.ini
This is the disk management screenshot from the server.
RHEL 6 & 7
ssax
Dreams In Code
Post by ssax »
Where are those other ones mounted to?
Open up a admin prompt on that server and PM me the output of these commands:
diskpart
list volume
