Cannot view or edited recently created checks in CCM
jeremyfleming
Post by jeremyfleming »
I have recently created and added some custom checks to NAGIOS from CCM. Now I can no longer see those checks to edit or delete them. I need assistance with correcting this so i can edit or even delete theses checks.
Jeremy
benjaminsmith
Re: Cannot view or edited recently created checks in CCM
Post by benjaminsmith »
Hi Jeremy,
There could be an error in your configurations, and it reverted to an older snapshot before you created the custom checks. Go to Admin > Monitoring Config > Config Snapshots, so see if you have any failed configurations.
If this is not the case, please send use your system profile along with the name of the customs checks you created, so I can check the configurations.
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
