Modification of MySQL to be security compliant - Supported?
steph007
Post by steph007 »
I'm using the OVA Linux CentOS Nagios XI download from your web site. For ESXi.
For security reason, the security team identified multiple MySQL parameters to changed.
I wondering if we can changed MySQL parameter and if it's supported to do that when using the OVA Linux image?
cdienger
Re: Modification of MySQL to be security compliant - Support
Post by cdienger »
Yes, you can make change if necessary. The OVA images are meant to be a quick way to set things up and test for the most part. Think of them not as an appliance but as a minimal CentOS image with XI installed.
steph007
Post by steph007 »
Thanks, if I'm not sure about what is requested by the security team, I will open a new ticket to have your advice.
cdienger
Post by cdienger »
Sounds good. I'll lock this thread.
