Alert if NO logs are received
jabi27
Post by jabi27 »
Any idea to create an alert if I haven't received any logs from a IP for ex 1 hour ?
Best
/Jan
jabi27
Re: Alert if NO logs are received
Post by jabi27 »
Found it
"Thresholds - This is what triggers the alert. A common use of the host freshness check is to detect when a host is no longer sending logs to Nagios Log Server. By using 0 for both warning and critical this will trigger a critical condition. Host Freshness alerts run once per hour and observe logs over the same amount of time"
cdienger
Post by cdienger »
That will do it. I'd only add out that alerts cant accept the Nagios threshold syntax which is covered in https://nagios-plugins.org/doc/guidelin ... HOLDFORMAT and the freshness checks work by searching the 'Not Sending' table under Reports.
