Hello
Any configuration need to change in nsclient++ if yes then plz tell me which file and what need to change.
Regards
Ajay Singh
Albionl Research Labs
Nsclient++
Re: Nsclient++
Ajay,
For configuring NSClient++ on the remote machine you will probably need to edit the nsc.ini that is usually located at C:\Program Files\NSClient++\nsc.ini.
The following is a very nice walkthrough of doing that:
http://www.thegeekstuff.com/2008/07/how ... x/#more-88
Nicholas Scott
