upgrade 2.1.4 => 2.1.6 performance issues
CBoekhuis
Post by CBoekhuis »
today I upgraded the cluster from 2.1.4 to 2.1.6. When assigning/allocating the shards after the upgrade, the cluster created an enormous load and the /var filesystem was filled up in no time due to the elasticsearch log file (> 1GB, as fast as the disks can write).
So far I've come to the concluesion that if I disable the NagiosXI service checks (NLS queries) the cluster can come up into a functional normal state. As soon as I enable 2 generic queries, each having +/- 90 hosts, the problem reappears. The common denominator in the elasticsearch logfile is as follows:
[2020-05-14 16:08:05,615][DEBUG][action.search.type       ] [bf328362-78a6-4a15-8f78-1878be74fe40] [logstash-2019.11.11][1], node[r-BKKVRzSP2uHSK70Sagjw], [R], s[STARTED]: Failed to execute [org.elasticsearch.action.search.SearchRequest@62267c5] lastShard [true]
org.elasticsearch.transport.RemoteTransportException: [dd139ec4-41a3-4780-95ef-9a564fb414ef][inet[/192.168.16.24:9300]][indices:data/read/search[phase/query]]
Caused by: org.elasticsearch.common.util.concurrent.EsRejectedExecutionException: rejected execution (queue capacity 1000) on org.elasticsearch.transport.netty.MessageChannelHandler$RequestHandler@72491ac4
        at org.elasticsearch.common.util.concurrent.EsAbortPolicy.rejectedExecution(EsAbortPolicy.java:62)
        at java.util.concurrent.ThreadPoolExecutor.reject(ThreadPoolExecutor.java:830)
        at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1379)
        at org.elasticsearch.common.util.concurrent.EsThreadPoolExecutor.execute(EsThreadPoolExecutor.java:79)
        at org.elasticsearch.transport.netty.MessageChannelHandler.handleRequest(MessageChannelHandler.java:224)
        at org.elasticsearch.transport.netty.MessageChannelHandler.messageReceived(MessageChannelHandler.java:114)
        at org.elasticsearch.common.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
        at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
        at org.elasticsearch.common.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
        at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:296)
        at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:462)
        at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.callDecode(FrameDecoder.java:443)
        at org.elasticsearch.common.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:303)
        at org.elasticsearch.common.netty.OpenChannelsHandler.handleUpstream(OpenChannelsHandler.java:74)
        at org.elasticsearch.common.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
        at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:268)
        at org.elasticsearch.common.netty.channel.Channels.fireMessageReceived(Channels.java:255)
        at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
        at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
        at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
        at org.elasticsearch.common.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
        at org.elasticsearch.common.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
        at org.elasticsearch.common.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
        at org.elasticsearch.common.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
For now I'm leaving the NagiosXI checks in disable state, but this I've never seen in a NLS upgrade. Has there been any changes that might throw the queue size problem?
Kind Regards,
Hans Blom
cdienger
Re: upgrade 2.1.4 => 2.1.6 performance issues
Post by cdienger »
Please PM a profile from the system. It can be gathered under Admin > System > System Status > Download System Profile or from the command line with:
/usr/local/nagioslogserver/scripts/profile.sh
This will create /tmp/system-profile.tar.gz.
Note that this file can be very large and may not be able to be uploaded through the ticketing system. This is usually due to the logs in the Logstash and/or Elasticsearch directories found in it. If it is too large, please open the profile, extract these directories/files and send them separately.
I'd also like to get a copy of the current settings index. This can be gathered by running:
curl -XPOST http://localhost:9200/nagioslogserver/_export?path=/tmp/nagioslogserver.tar.gz
The file it creates and that we'd like to see is /tmp/nagioslogserver.tar.gz.
CBoekhuis
Post by CBoekhuis »
PM has been eens. ;)
cdienger
Post by cdienger »
Everything looks good in the data provided. Can you enable the service checks just long enough to reproduce the message in the logs and then send a copy of the logs?
I'd also like to get a copy of the XI config. This can be done from the command line usually with:
mysqldump -uroot -pnagiosxi nagiosql > nagiosql.sql
The above will work on most XI instances unless you've offloaded the database to another system. In which case you'd need to something like:
mysqldump -h database_host_ip -uusername -ppassword nagiosql > nagiosql.sql​​
If you're not sure about the credentials or database server IP you can review /usr/local/nagiosxi/html/config.inc.php​ which will have database connection information.
CBoekhuis
Post by CBoekhuis »
I sent you the files in a PM.
Unfortunately I also ran into another problem. Since the update the maintenance job fails, no snapshots are created. LS thinks that a snapshot is already in progres. I ran the maintenance job by hand with a tail on the jobs.log. The output of the tail is in the attached file along with a listing of the snapshot indices which shows that it stops after may the 14th.
Here's also a screenshot of the snapshot & maintenance page:
Greetings...Hans
cdienger
Post by cdienger »
Please provide a directory listing(ls -alh) of the snapshot directory as well as the output of:
curl -XGET 'http://localhost:9200/_snapshot/nls_prd1/_all?pretty'
CBoekhuis
Post by CBoekhuis »
As requested.
cdienger
Post by cdienger »
Run:
ps aux | grep curator
and assuming you don't see any curator scripts running you can delete the stuck job:
curl -XDELETE 'http://localhost:9200/_snapshot/nls_prd1/curator-20200515112510'
If there are still any issues, please try running the job from the command line:
/usr/local/nagioslogserver/scripts/curator.sh snapshot --repository 'nls_prd1' --ignore_unavailable indices --older-than 1 --time-unit days --timestring %Y.%m.%d
and provide the output of:
ls -alh /nfs_mounts/logserver/prd1/
CBoekhuis
Post by CBoekhuis »
With the delete I got the snapshots into a good state. Afterwards I ran a succesfull new snapshot.
I also enabled the Nagios XI services to see if that problem mighgt be solved aswell, but that problem is still in effect.
cdienger
Post by cdienger »
Run the following:
curl 'localhost:9200/_cat/thread_pool?v&h=id,host,search.active,search.rejected,search.completed,search.size,search.queue,search.type,search.queueSize,search.min,search.max,search.keepAlive,search.largest'
on the machine when the check is disabled, again when it is enabled, and final time after you edit /usr/local/nagioslogserver/elasticsearch/config/elasticsearch.yml on each NLS machine in the cluster and add this to the bottom/restart elasticsearch:
threadpool.search.queue_size: 2000
restart the elasticsearch service after making the change to elasticsearch.yml:
service elasticsearch restart
