NRPE - Full Guide to install it offline
OmarNaji1
Post by OmarNaji1 »
Hello Dears,
I must install Nagios agent ( NRPE ) in the offline server ( no connection to the internet ).
the problem is during NRPE Installation is using the internet to get some package and its return the below error.
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
so please support is there any way to install it in offline server with full installation step by step.
INSTALL LOG :
Nagios Linux Agent Installation Log
DATE: Thu May 14 19:06:07 GST 2020
DISTRO INFO:
RedHatEnterpriseServer
7.3
x86_64
Configuring Repos...
Enabling EPEL repo...
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-
              : manager
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
Repodata is over 2 weeks old. Install yum-cron? Or run: yum makecache fast
file:///mnt/addons/HighAvailability/repodata/repomd.xml: [Errno 14] curl#37 - "Couldn't open file /mnt/addons/HighAvailability/repodata/repomd.xml"
Trying other mirror.
file:///mnt/addons/ResilientStorage/repodata/repomd.xml: [Errno 14] curl#37 - "Couldn't open file /mnt/addons/ResilientStorage/repodata/repomd.xml"
file:///mnt/repodata/repomd.xml: [Errno 14] curl#37 - "Couldn't open file /mnt/repodata/repomd.xml"
No package epel-release available.
Error: Nothing to do
Installing EPEL PKG: ./packages/epel-release-latest-7.noarch.rpm
warning: ./packages/epel-release-latest-7.noarch.rpm: Header V3 RSA/SHA256 Signature, key ID 352c64e5: NOKEY
Preparing...                          ########################################
Updating / installing...
epel-release-7-10                     ########################################
              : manager
 One of the configured repositories failed (Unknown),
 and yum doesn't have enough cached data to continue. At this point the only
 safe thing yum can do is fail. There are a few ways to work "fix" this:
     1. Contact the upstream for the repository and get them to fix the problem.
     2. Reconfigure the baseurl/etc. for the repository, to point to a working
        upstream. This is most often useful if you are using a newer
        distribution release than is supported by the repository (and the
        packages for the previous distribution release still work).
     3. Run the command with the repository temporarily disabled
            yum --disablerepo=<repoid> ...
     4. Disable the repository permanently, so yum won't use it by default. Yum
        will then just ignore the repository until you permanently enable it
        again or use --enablerepo for temporary usage:
            yum-config-manager --disable <repoid>
        or
            subscription-manager repos --disable=<repoid>
     5. Configure the failing repository to be skipped, if it is unavailable.
        Note that yum will try to contact the repo. when it runs most commands,
        so will have to try and fail each time (and thus. yum will be be much
        slower). If it is a very temporary problem though, this is often a nice
        compromise:
            yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot retrieve metalink for repository: epel/x86_64. Please verify its path and try again
epel-release RPM installed OK
Repos configured OK
Installing prerequisites...
              : manager
        or
        compromise:
Best Regards
jbrunkow
Re: NRPE - Full Guide to install it offline
Post by jbrunkow »
I believe you will need to download the RPM and all of it's dependencies, and then install it from source.
Please refer to the following documentation for more detailed instructions on how to do this.
https://support.nagios.com/kb/article.php?id=515
OmarNaji1
Post by OmarNaji1 »
Dear jbrunkow,
Thanks for your reply, already tried to follow that document but my isssue was for first command.
yum install -y gcc glibc glibc-common openssl openssl-devel perl wget
its return the below output.
[root@localhost ~]# yum install -y gcc glibc glibc-common openssl openssl-devel        perl wget
              : manager
This system is not registered to Red Hat Subscription Management. You can use su        bscription-manager to register.
file:///mnt/addons/HighAvailability/repodata/repomd.xml: [Errno 14] curl#37 - "C        ouldn't open file /mnt/addons/HighAvailability/repodata/repomd.xml"
file:///mnt/addons/ResilientStorage/repodata/repomd.xml: [Errno 14] curl#37 - "C        ouldn't open file /mnt/addons/ResilientStorage/repodata/repomd.xml"
        or
        compromise:
do we have this one as package to extract it and install.
Best Regards.
jbrunkow
Post by jbrunkow »
I believe you can download the packages on an internet connected system using the downloadonly plugin or yumdownloader on a system that already has the packages installed.
yum install yum-plugin-downloadonly
yum install --downloadonly --downloaddir=<[i]directory[/i]> <[i]package[/i]>
link
Then you can move it to the offline system (using scp or similar...), and then run something like the following set of commands.
yum install --downloadonly --installroot=<[i]directory[/i]> --releasever=<[i]version[/i]> --downloaddir=<[i]directory[/i]> <[i]package[/i]>
As for how you would update the system after that is another matter... Options for that include re-downloading every update using an online machine, setting up a local repository, or setting up a local mirror.
LINK
OmarNaji1
Post by OmarNaji1 »
Thank you for support and answer.
it was very helpfully to me.
Best regards,
jbrunkow
Post by jbrunkow »
I'm glad to hear that!
Were you able to get it installed offline?
Please let me know if you have any more questions. Otherwise, we can lock this thread for editing so that it can be archived for future reference.
OmarNaji1
Post by OmarNaji1 »
Hi dear,
I solved this one by below steps.
first, I get the package of below command by yum download-only and take a copy to my Linux host.
Sudo yum install -y gcc glibc glibc-common openssl openssl-devel perl wget
and same for
sudo yum install -y perl-Net-SNMP
then I downloaded epel from below link and take a copy also to Linux host
then run the below commnad
sudo rpm -qa | grep -i epel
sudo rpm -qi epel-release-7-12.noarch       //change the name to same file name
sudo rpm -e epel-release-7-12.noarch        //change the name to same file name
that is all requested for NRPE for my case.
Thanks and Best regards.
