Dear Expert
I have added Performance graph as a Container but its refreshing every 5 seconds.
How to increase refresh timer in Nagvis per Container or per Object level?
I tried (under the Object) trial and error but no success
define container {
object_id=239e91
#refreshtime=30
#updateobjectstates=60
url=www.thegreatnagios.com
view_type=iframe
enable_refresh=1
regards
nagvis Object or Container refresh time setting
Re: nagvis Object or Container refresh time setting
refreshtime is the only option I'm aware of and it defaults to 60 seconds. Can you provide a screenshot showing what is refreshing? I'd also like to get a copy of the Nagvis config so I can take a closer look/reproduce. The Nagvis config is in /usr/local/nagvis/. Please PM the complete directory.
