Migrating User's Dashboard to New NagiosXI Server
elealyngarcia
Post by elealyngarcia »
Hi
We are currently migrating our NagiosXI from RHEL 6 to RHEL7 and reinstalling and importing all the configs. Is there a way to migrate the user's dashboard to the new server?
benjaminsmith
Re: Migrating User's Dashboard to New NagiosXI Server
Post by benjaminsmith »
Hi @elealyngarcia ,
I would recommend using the backup and restore process outline in the following guide as it will migrate everything to the new server.
Backing Up And Restoring Your Nagios XI System
You'll want to migrate between the same versions of Nagios XI. So if you have an older version running, install that on the new XI server, restore and then upgrade to the lastest.
Previous Versions of Nagios XI
I hope that helps and let me know If you have any questions.
Benjamin
