Monitoring a Nagios Server's Health & MySQL
luczynj
Post by luczynj »
Hello Nagios Support!
We've been trying to manage our Nagios XI servers and find that we are missing out on some very important services to look at.
We would think that Nagios XI Servers should be fully able to manage itself, after running a CCM Wizard.
We would expect that if you ran the Nagios XI server wizard, that the instance of Nagios XI that's running would have visibility of *everything* related to Nagios XI and would create Nagios XI services for nearly every area of the system. Including:
MySQL database monitoring
Various Nagios-related O/S service checks (IE, ensuring ipcs is working properly).
Checking that some/all OS-level services are "running", especially those required for Nagios XI to run.
Checking any timeouts aren't breached. IE, we are having PHP issues where PDF reports are being emailed out but the contents of the file are plain text and says "Your session has timed out.".
Checking its own ethernet ports bandwidth
Checking for latest O/S security patches for the server(s),
Checking the Nagios logs for any issues that are occurring that aren't obvious to the admins.
We had an issue a few years ago where for some reason, one of the two nagios -d process wasn't running. We now have a script that checks for it and restarts the nagios services if need be.
We also have a custom Nagios XI service (with the help of ssax) that checks that there are two instances of this command line to ensure Nagios is running correctly.
nagios 38235 1 4 14:58 ? 00:01:43 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 39363 38235 0 14:58 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
We've built several custom services that look at activity on our XI servers.
I just tried to do the add Nagios XI server wizard, and it added some JSON services that went straight into critical mode. I've not looked up what they are, so I've disabled them for now.
We just tested the MySQL wizard in our model and have some questions about that that I'm going to put in a separate post.
I hope I explained my request clearly. I effectively would like to be able to run one Nagios-XI wizard that will interrogate our entire Nagios-XI system, it's O/S, the filesystems, the memory, the swap, and any other services/OS features that could possibly go wrong... without us having to do it by component.
Many thanks,
JL
cdienger
Re: Monitoring a Nagios Server's Health & MySQL
Post by cdienger »
Thanks for the suggestions. I will file a feature request for improvements tot he wizard. In the meantime, do you want help setting any of these up or are you good with the enhancement request?
luczynj
Post by luczynj »
I've discussed this with my colleague and we would love some help. Can we do a screen sharing session? We've purchased the 10 pack of support calls.
Thank you,
JL
cdienger
Post by cdienger »
Please open a ticket at https://support.nagios.com/tickets/ or give us a call(contact number at https://www.nagios.com/contact/) and we'll be able to assist further. Please include the last 6 characters of your license or have it ready when you call so we can confirm phone support.
luczynj
Post by luczynj »
Will do. What hours are you able to assist? I'm currently in London (EST+5) and my colleague is in Belgium. (EST+6).
Are you able to dial international? Or do a Skype/Teams meeting?
cdienger
Post by cdienger »
Our hours are 9-5 CST Monday - Thursday and 9-2 CST on Friday. We can call you if needed or set a Webex and dial into that.
luczynj
Post by luczynj »
Sorry for the delayed response. How does Monday, June 15th work with you?
We would be able to start at the beginning of your day. 9am CST, 16:00 London time, and 17:00 Belgium time. Is that OK with you?
EDIT: I missed the part where I need to raise a ticket. I'll do that now. I need to coordinate with my colleague in Belgium.
Regards,
JL
cdienger
Post by cdienger »
Sounds good. Locking Thread.
