Hi I have problem for list logstash plugin
Gem::LoadError: You have already activated minitar 0.6.1, but your Gemfile requires minitar 0.5.4. Prepending `bundle exec` to your command may solve this.
I search this message into google and return a page on this forum that i can't see... can you help me?
logstash plugin error
Re: logstash plugin error
who can i obtain the list of logstash plugin into nagioslog?
There isn't a resolution listed in there other than checking your umask/permissions (it was resolved in a remote session so there aren't further details).
Is this occurring on a Nagios Log Server installation?
Yes we have a NagiosLog 2.15 (updated from 2.0.8)
I'll see that folder local_gem are with root:root privilegies, I had changed but this not fix the issue
./logstash-plugin list
setup at /nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler/runtime.rb:34
each at org/jruby/RubyArray.java:1613
each at /nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/forwardable.rb:201
setup at /nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler/runtime.rb:19
setup at /nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler.rb:122
setup! at /nagioslogserver/logstash/lib/bootstrap/bundler.rb:64
execute at /nagioslogserver/logstash/lib/pluginmanager/list.rb:17
run at /nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/clamp-0.6.5/lib/clamp/command.rb:67
execute at /nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/clamp-0.6.5/lib/clamp/subcommand/execution.rb:11
run at /nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/clamp-0.6.5/lib/clamp/command.rb:132
(root) at /nagioslogserver/logstash/lib/pluginmanager/main.rb:43
drwxrwxr-x. 7 nagios nagios 229 Apr 29 13:16 .
drwxrwxr-x 10 nagios nagios 264 Apr 29 12:39 ..
drwxrwxr-x. 2 nagios nagios 194 Mar 21 2018 bin
-rwxrwxr-x. 1 nagios nagios 138 Dec 21 2017 CHANGELOG
-rwxrwxr-x 1 nagios nagios 102879 Mar 31 09:31 CHANGELOG.md
-rwxrwxr-x. 1 nagios nagios 2249 Mar 31 09:31 CONTRIBUTORS
drwxrwxr-x. 3 nagios nagios 20 Dec 21 2017 etc
-rwxrwxr-x 1 nagios nagios 8555 Mar 31 09:32 Gemfile
-rwxrwxr-x. 1 nagios nagios 37531 Mar 31 09:32 Gemfile.jruby-1.9.lock
-rwxrwxr-x 1 nagios nagios 308522020 Jun 18 2019 heapdump.hprof.gz
drwxrwxr-x. 4 nagios nagios 44 Mar 31 09:31 lib
-rwxrwxr-x. 1 nagios nagios 589 Mar 31 09:31 LICENSE
-rwxrwxr-x 1 nagios nagios 149 Mar 31 09:31 NOTICE.TXT
drwxrwxr-x 2 nagios nagios 20 Jun 18 2019 patterns
drwxrwxr-x. 5 nagios nagios 51 Mar 31 09:31 vendor
We still have this error in NagiosLog server 2.1.5
There is a checklist for verifiy this problem?
I was able to replicate this, I was able to fix it by removing the newer duplicate gem file.
I will be submitting a bug report for this so the developers can fix it.
Edit (submitted):
Try this:
Then run the command again:
If you need to revert for whatever reason, you can run this command:
Let us know the results.
Edit (submitted):
NEW TASK ID 15169 created - Nagios Log Server Bug Report: LS - Fresh install of LS 2.1.6 has duplicate gemfiles for minitarCode: Select all
mv /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/minitar-0.6.1 /root/Code: Select all
/usr/local/nagioslogserver/logstash/bin/logstash-plugin list --verboseIf you need to revert for whatever reason, you can run this command:
mv /root/minitar-0.6.1 /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/
