Create service by command line
steph007
Post by steph007 »
I'm using something the Bulk Host Cloning and Import to create multiple Hosts in Nagios XI, and I wondering if something similar exist for Services?
I have to create a lot of services and would use something similar.
If not, is there a command line that I can use to create a service? I could at that moment use a script to create all my services I need to add.
benjaminsmith
Re: Create service by command line
Post by benjaminsmith »
Hi @steph007,
There are couple of options here. One approach is to create a service and then assigned this service to a hostgroup in the CMM. All of the hosts in the hostgroup will inherit the service.
We have a Pro Tip video on how to do this that I would recommend watching.
https://youtu.be/Qj_HALNyWvc
You can also use the REST API to add a service to a host. The API is fully documented in the user interface, got to Help > API Docs. Then find the Config Reference in the left-hand sidebar, and got to POST > config/service.
Let us know if you have more questions.
steph007
Post by steph007 »
Thanks, I chose to create file and import it in Nagios
steph007 wrote:Thanks, I chose to create file and import it in Nagios
Great!
Locking thread
