Hi guy can you help me on this problem. below error for my nagios .. this error at my server. details mys server: windows server 2008
disk_windows_c = CRITICAL 05-21-2012 11:29:01 0d 0h 4m 58s 4/4 CHECK_NRPE: Socket timeout after 10 seconds.
mem_windows = CRITICAL 05-21-2012 11:28:29 0d 0h 24m 16s 4/4 CHECK_NRPE: Socket timeout after 10 seconds.
Check NRPE
Re: Check NRPE
Moving this a support forum, it will get more eyes there.
Nicholas Scott
Re: Check NRPE
Do you have NSClient++ (or another nagios agent) installed on your windows 2008 server? Are you able to provide the command and service definitions?
Re: Check NRPE
If you are still having issues, try running the check in NSClient++'s test mode. You can still run the command from your Nagios server but have a cmd opened and test mode on.
