Hi:
I don´t know why but i can't start the ssh terminal from the Nagios Admin section.
I received this massage: This site can’t be reachedThe webpage at https://10.200.xxx.xxx/nagiosxi/terminal might be temporarily down or it may have moved permanently to a new web address.
ERR_TUNNEL_CONNECTION_FAILED
It´s happend since a tiem ago.
We doesn´t change nothing.
Nagios XI version 5.6.14
Thank you!.
SSH Terminal - this site can't be reached
Re: SSH Terminal - this site can't be reached
If you go to Admin->System Settings->Security tab, there's a checkbox for disabling the SSH terminal. Make sure that's set correctly.
Do you get a different message if you go to https://yourxiserver/nagiosxi/admin/sshterm.php ?
--Jeffrey
--Jeffrey
