Backup before upgrade - Tiny question
srrhd
Post by srrhd »
To upgrade our server, i always followed the XI_Upgrade_Instructions.pdf, but it means stopping the service for more than 30 minutes. What about using xi_backup.sh instead ?
This script doesn't stop the service and has the advantage to allow thye use of xi_restore.sh in case of trouble. Is this idea a good one or not ?
Aurelien.
Configuration:
Nagios XI 2014R2.5
manually upgraded on 64bits CentOS 6
with nothing extra, no gnome, no proxy, no SSL
Add-ons: Hypermap, Minemap, Ping Action, Traceroute Action, Network Replay, Graph Explorer, Latest Alert
Re: Backup before upgrade - Tiny question
Honestly, I personally prefer the xi_backup.sh method, and it is really a more complete backup.
I think an upgrade to the documentation may be in order.
The one difference is that the xi_backup.sh assumes that the install is using the passwords set at install and they have not been changed.
srrhd
Post by srrhd »
Thanks for the quick answer. I will follow your preference.
Configuration:
Nagios XI 2014R2.5
srrhd
Post by srrhd »
Just to inform you, the upgrade didn't worked. I had the exact same behavior as described in this thread:
http://support.nagios.com/forum/viewtop ... it=upgrade
The fix you provided by Scott also worked for me.
Configuration:
Nagios XI 2014R2.5
Just to verify - is your problem fixed?
