SSO / SAML / OpenID Connect
mrmit
Post by mrmit »
Is it possible to use an apache authentication module instead of XI authentication page Nagios XI?
I cannot find any documentation on Authentication in XI other than AD with manuel user sync and email 2fa. This is simply not enough in a modern IT environment.
Specifically I am looking to use Azure AD MFA through either SAML2.0 or OpenIDC/OAUTH2. I can use mod_auth_openidc for this if Nagios XI can use the REMOTE_USER variable and match it to the username.
ssax
Dreams In Code
Re: SSO / SAML / OpenID Connect
Post by ssax »
Not currently possible unless you are using DUO:
https://support.nagios.com/kb/article/n ... n-834.html
The devs would need to add that functionality in.
I've created a feature request for this on your behalf:
FR: XI - Add other MFA types for XI sign-in (SSO/SAML/OATH2/OpenID/etc)
Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
