Good evening,
Is it possible to do a massive downtime to a host and all of its services.
I would like to do with external command via nagios.cmd
What would be the syntax?
Many Thanks in advance
KR
Massive DownTime with nagios.cmd pipe
FCC_Nagios_Support
Re: Massive DownTime with nagios.cmd pipe
I believe this is the command you are looking for
https://assets.nagios.com/downloads/nag ... mand_id=28
