looking to build a test instance by cloning my existing prod nagiosxi server.
successful clone
disconnected eth adapter
changed IP address
stopped nagios
ran these commands and verified in nagios.cfg
sed -i 's/enable_notifications=1/enable_notifications=0/' /usr/local/nagios/etc/nagios.cfg
sed -i 's/execute_service_checks=1/execute_service_checks=0/' /usr/local/nagios/etc/nagios.cfg
sed -i 's/execute_host_checks=1/enable_notifications=0/' /usr/local/nagios/etc/nagios.cfg
echo "update xi_options set value = 'https://192.168.3.3/nagiosxi/' where name = 'url';" | mysql -uroot -pnagiosxi nagiosxi
after this i rebooted connected nic
few minutes later my users started getting flooded w/ timeout errors. we have a mix of passive/active checks.
not sure what i'm doing wrong?
Creating Test Environment from Clone
Re: Creating Test Environment from Clone
They only way that I could get it to fail is if I had enable_notification=0, then started up nagios, then changed Admin > Monitoring Engine Status to change the runtime config to turn Notifications on, then rebooted and it still was enabled. I'm wondering if your runtime config was overriding it like that. Could that have happened?
Additionally, you have an error in your command (related but still needs to be resolved) and will likely need to update the nagios.cfg file to remove one of the enable_notifications=0 and replace it with the proper execute_host_checks line:
This:
Should be this:
For why they are actually timing out though:
Did you also update all the agents and firewall rules to allow incoming connections from the new servers IP? As they have different IP addresses you will need to update the agents/FW rules/etc to allow them.
This:
sed -i 's/execute_host_checks=1/enable_notifications=0/' /usr/local/nagios/etc/nagios.cfgCode: Select all
sed -i 's/execute_host_checks=1/execute_host_checks=0/' /usr/local/nagios/etc/nagios.cfgFor why they are actually timing out though:
