Incorrect Status Reporting
buee
Post by buee »
I have a strange problem this morning. I have 3 TrippLite battery backups out in the field that I monitor from Nagios via SNMP for their electrical status. This morning, all 3 of them entered critical status for no reason:
***** Nagios *****
Notification Type: PROBLEM
Service: Battery Status
Host: germanvalley_bbu
Address: 10.0.4.2
State: There has been a change in power status
Date/Time: Mon May 21 09:34:34 CDT 2012
Additional Info:
SNMP CRITICAL - *3*
The SNMP is supposed to return "3".
Here is the command definition:
# Custom SNMP - BBU Run Status
        command_name    check_bbu
        command_line    /usr/lib/nagios/plugins/check_snmp -H $HOSTADDRESS$ -o .1.3.6.1.2.1.33.1.4.1.0 -C public -P 2c -s 3 -w $ARG1$ -c $ARG2$
And here is the service definition:
        host_name               German Valley BBU
        service_description     Battery Status
        check_command           check_bbu!5!2
        contact_groups          palspower
When I run `/usr/lib/nagios/plugins/check_snmp -H $HOSTADDRESS$ -o .1.3.6.1.2.1.33.1.4.1.0 -C public -P 2c -s 3` (replacing $HOSTNAME$ with the correct IP of course), it returns OK. Can anyone help me out on this?
nscott
Re: Incorrect Status Reporting
Post by nscott »
Well its certainly strange that it changed status. However, are you sure that it is returning EXACTLY 3? Can you run the plugin with those arguments and make sure that its not returning extra data beyond the expected 3?
Nicholas Scott
buee
Post by buee »
nscott wrote:Well its certainly strange that it changed status. However, are you sure that it is returning EXACTLY 3? Can you run the plugin with those arguments and make sure that its not returning extra data beyond the expected 3?
root@monitor:~# /usr/lib/nagios/plugins/check_snmp -H 10.0.4.2 -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c
SNMP OK - 3 | iso.3.6.1.2.1.33.1.4.1.0=3
root@monitor:~# /usr/lib/nagios/plugins/check_snmp -H 10.0.4.2 -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c -s =3
SNMP CRITICAL - *3* | iso.3.6.1.2.1.33.1.4.1.0=3
root@monitor:~# /usr/lib/nagios/plugins/check_snmp -H 10.0.4.2 -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c -s 3
root@monitor:~# /usr/lib/nagios/plugins/check_snmp -H 10.0.4.2 -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c -s *3*
root@monitor:~# /usr/lib/nagios/plugins/check_snmp -H 10.0.4.2 -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c -s "3"
So perhaps adding quotes around the 3 would help? It's weird that this just randomly started happening today though.
buee
Post by buee »
FYI adding the quotes did not help.
nscott
Post by nscott »
Yeah, I don't know the device would being returning *3* at this point but you'll definitely have to add something that will account for it doing that. It looks like its alternating between 3 and *3*?
The reason this happened:
Is because those * got expanded, can you try this:
/usr/lib/nagios/plugins/check_snmp -H 10.0.4.2 -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c -r "\*?3\*?"
But perhaps, depending on the datatype (if the this is actually an integer datatype) you could use
/usr/lib/nagios/plugins/check_snmp -H 10.0.4.2 -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c -c 3:3
This last one would be ideal if the OID is of Integer type.
Nicholas Scott
buee
Post by buee »
nscott wrote:Yeah, I don't know the device would being returning *3* at this point but you'll definitely have to add something that will account for it doing that. It looks like its alternating between 3 and *3*?
These:
While working from the command line did not bring the service in to an OK state.
I found this log entry if it helps:
[1337615276] SERVICE ALERT: German Valley BBU;Battery Status;CRITICAL;SOFT;2;SNMP CRITICAL - *3*
[1337615336] SERVICE ALERT: German Valley BBU;Battery Status;CRITICAL;SOFT;3;SNMP CRITICAL - *3*
[1337615396] SERVICE ALERT: German Valley BBU;Battery Status;CRITICAL;HARD;4;SNMP CRITICAL - *3*
nscott
Post by nscott »
What happened when you ran this one:
Nicholas Scott
buee
Post by buee »
nscott wrote:What happened when you ran this one:
It returns OK from command line but doesn't change the status in Nagios.
nscott
Post by nscott »
How are you changing it in Nagios? Keep in mind the actual flag is being changed from -s to -c.
Nicholas Scott
buee
Post by buee »
nscott wrote:How are you changing it in Nagios? Keep in mind the actual flag is being changed from -s to -c.
Changed it in the commands.cfg file:
        command_line    /usr/lib/nagios/plugins/check_snmp -H $HOSTADDRESS$ -o .1.3.6.1.2.1.33.1.4.1.0 -C 1RC0MM -P 2c -c 3:3 -w $ARG1$ -c $ARG2$
