Force sequential checks on services
giponino
Post by giponino »
Hi, I know this argument has been discussed about 4 years ago from other users, but i would like to know if this feature was officially implemented or not. What I need is to force a sequential run of some service checks, to avoid them to run in parallel (or have a maximum number running in parallel).
es. host A
service A
service B
service C
start service A
end service A
start service B
end service B
start service C
end service C
Thank you
Matteo
benjaminsmith
Re: Force sequential checks on services
Post by benjaminsmith »
Hi Matteo,
There is an option in the main configuration file called max_concurrent_checks that will limit the maximum number of parallel checks. I'm not quite certain when that option was introduced, but take a look at the Nagios Core documentation on Check Scheduling and let us know if this would meet your requirements.
Host and Service Check Scheduling
More details on the setting itself in the main config options documentation:
Main Configuration File Options
