access "Home" very slow
winsonlee
Post by winsonlee »
when click "Home" or new login,it need about 1 min, what can I do to fix this problem?
jdunitz
Re: access "Home" very slow
Post by jdunitz »
Could you PM a system profile?
You can generate one from the command line, like so:
/usr/local/nagioslogserver/scripts/profile.sh
Then, you should find the file we need in /tmp.
Thanks!
winsonlee
Post by winsonlee »
already send profile via pm
ssax
Dreams In Code
Post by ssax »
Please run this command as root and leave it running:
tail -Fn0 /var/log/httpd/error_log /var/log/httpd/ssl_error_log
Then replicate the delay behavior and once you're finished logging in PM me the full output of that command.
Thank you!
jdunitz
Post by jdunitz »
We didn't see anything in your profile that would indicate a serious problem.
You might try going through this document:
https://support.nagios.com/kb/article.php?id=132
Let us know if that helps.
--Jeffrey
winsonlee
Post by winsonlee »
jdunitz wrote:We didn't see anything in your profile that would indicate a serious problem.
--Jeffrey
i change php.ini memory_limit to 512M, it still very slow, and "Number of Logs Per 15 minutes" show "no data to display".
my index primary size is 320GB and docs count about 340,000,000 per day, and we have 4 log server node and shards number is 5 now
should i increase shards number or do something?
ssax
Dreams In Code
Post by ssax »
Please send the output of this command:
cat /etc/sysconfig/logstash
Please send us a screenshot of your current settings in Admin > Snapshots and Maintenance.
I also see that you have a lot of large indices open, I recommend that you setup Snapshots and Maintenance to close indices older than 5 days if they are that large. See here:
https://assets.nagios.com/downloads/nag ... enance.pdf
winsonlee
Post by winsonlee »
# Default settings for logstash
# Override Java location
#JAVACMD=/usr/bin/java
# Set a home directory
APP_DIR=/usr/local/nagioslogserver
LS_HOME="$APP_DIR/logstash"
# set ES_CLUSTER
ES_CLUSTER=$(cat $APP_DIR/var/cluster_uuid)
# Arguments to pass to java
#LS_HEAP_SIZE="256m"
LS_HEAP_SIZE="2G"
LS_JAVA_OPTS="-Djava.io.tmpdir=$APP_DIR/tmp"
# Logstash filter worker threads
#LS_WORKER_THREADS=1
# pidfiles aren't used for upstart; this is for sysv users.
#LS_PIDFILE=/var/run/logstash.pid
# user id to be invoked as; for upstart: edit /etc/init/logstash.conf
LS_USER=nagios
LS_GROUP=nagios
# logstash logging
#LS_LOG_FILE=/var/log/logstash/logstash.log
#LS_USE_GC_LOGGING="true"
# logstash configuration directory
LS_CONF_DIR="$LS_HOME/etc/conf.d"
# Open file limit; cannot be overridden in upstart
#LS_OPEN_FILES=2048
# Nice level
#LS_NICE=0
# Increase Filter workers to 4 threads
LS_OPTS=" -w 4"
if [ "x$1" == "xstart" -o "x$1" == "xrestart" -o "x$1" == "xreload" ];then
GET_LOGSTASH_CONFIG_MESSAGE=$( php /usr/local/nagioslogserver/scripts/get_logstash_config.php )
GET_LOGSTASH_CONFIG_RETURN=$?
if [ "$GET_LOGSTASH_CONFIG_RETURN" != "0" ]; then
echo $GET_LOGSTASH_CONFIG_MESSAGE
exit 1
fi
fi
ssax
Dreams In Code
Post by ssax »
Did you do this?
Additionally, attach your /etc/php.ini as well.
winsonlee
Post by winsonlee »
/etc/php.ini is default, except "memory_limit" change to 512M, plz see attached file
