Hello XI support
How to add SQL Agent job, cdc.Siebeldb_capture process which needs to have status “Executing”.
- monitor the SQL job status / If the status is anything else than “executing” it is critical.
How to monitor running SQL job
Re: How to monitor running SQL job
There are few here for MSSQL checking jobs, you will need to test them out to see if they meet your needs, I haven't personally used them:
https://exchange.nagios.org/directory/P ... /SQLServer
This one is marked as popular:
https://exchange.nagios.org/directory/P ... ng/details
See here for the XI side:
Let us know if you have any questions.
Thank you!
Thank you!
Thank you, please close the thread
Great!dlukinski wrote:Thank you, please close the thread
Locking thread
