HI,
I want to delete reports but nagios hung whe i select.
Any idea?
Thks
KR
Reports
Re: Reports
What do you see in the SSL log or the error log for around the time the report was ran?
It is possible that the PHP is exhausting its limits, if it is a larger report. See the linked documentation for detailed instructions on how to change the PHP settings on your operating system.
TROUBLESHOOTING REPORTS
OPTIMIZING PHP SETTINGS
It wouldn't be a bad idea to restart your Apache and/or Nagios services on that machine if they're hung either...
/var/log/httpd/error_log
/var/log/httpd/ssl_error_logTROUBLESHOOTING REPORTS
