Nagios XI 5.7 NDO Error
fullsail
Post by fullsail »
I have ran the upgrade to 5.7 on my Nagios XI environment and am not seeing any hosts/services. I do run an external NDO2DB server which I have upgraded. Looking at the nagios.log I see this error, Is this a simple fix or do I need to roll back.
[1591642501] NDO-3: ndo_return = 1 (Statement not prepared)
[1591642501] NDO-3: ndo_handle_service_status(ndo-handlers.c:952): Unable to bind parameters
[1591642501] NDO-3: ndo_handle_host_status(ndo-handlers.c:860): Unable to bind parameters
benjaminsmith
Re: Nagios XI 5.7 NDO Error
Post by benjaminsmith »
Hi @FullSail,
Since the database was offloaded, I believe this is a settings issue in the ndo configuration file. Go to vi /usr/local/nagios/etc/ndo.cfg, and find the following entry:
db_host=localhost
And then change this to the location of the remote server.
db_host=10.26.7.11
Additionally, there's a directive in that file for the database password, make sure that is set correctly, and let me know if the issue is resolved for you. If not, please send us a fresh system profile, temporarily roll it back and we'll review the logs to try and determine the cause. Thanks.
To send us your system profile.
Login to the Nagios XI GUI using a web browser
Save the profile.zip file and share this in a private message and then reply to this post to bring it up in the queue.
swolf
Post by swolf »
Hi @FullSail,
I agree with everything Benjamin said, but I just wanted to add that you should be able to remove the ndo2db process/message queue entirely once we have this issue figured out. XI 5.7/NDO-3 handles everything from inside the main nagios process, so you should only need to configure the direct connection to the database.
fullsail
Post by fullsail »
In the ndo.cfg the upgrade script pulled in the correct info.
db_user db_pass db_name db_host db_port are all set correctly. I am able to use MySQL client with the credentials and the connection works successfully. I have the upgraded system but it is now offline as we had rolled back. I will PM you a System Profile from the current production system (before upgrade on 5.6.14 with offloaded ndo/mysql. I will see if I can get a system profile off the one that was upgraded. Is there a command line I can run to pull it so that I don't have to bring it back up?
benjaminsmith
Hi FullSail,
I just replied to your private message, the profile was not attached to the message. Please try to send this once more. Thanks.
To generate a profile from the command line, run the following:
/usr/local/nagiosxi/scripts/components/getprofile.sh support
# The profile will be in the following directory:
/usr/local/nagiosxi/var/components/profile.zip
fullsail
Post by fullsail »
I waited for 5.7.2 and the upgrade completes without the errors here.
benjaminsmith
That's good to hear!
Thanks for the update.
Benjamin
