How to change the sender's name in Notification
Pratapa
Post by Pratapa »
In the notification which users receive, the sender's name is [email protected]
where asadinf.ae.corp is the Nagios production server.
User wants the sender's name as Nagios instead of [email protected]
How can this be achieved. We are using Nagios core.
benjaminsmith
Re: How to change the sender's name in Notification
Post by benjaminsmith »
Hi Pratapa,
After doing some research on this, you should be able to set this in the notification commands for hosts and services by adding -r $ADMINEMAIL$ to the command string.
Take a look at the following thread for more details and let us know how it goes.
how to change the default sender of nagios mail notification
Pratapa
Post by Pratapa »
Following is the service command definition in notifications.cfg
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nHostname: $HOSTNAME$\nAddress: $HOSTADDRESS$\nResolver Group: $_SERVICERESOLVER_GROUP$\nService Notes: $SERVICENOTESURL$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTNAME$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
and following is the one which is defined in nagios.cfg file
# ADMINISTRATOR EMAIL/PAGER ADDRESSES
# The email and pager address of a global administrator (likely you).
# Nagios never uses these values itself, but you can access them by
# using the $ADMINEMAIL$ and $ADMINPAGER$ macros in your notification
# commands.
admin_email=nagios@localhost
how should I append $ADMINEMAIL$ in service command definition
I think I should change admin_email=nagios@localhost to admin_email=Nagios in nagios.cfg file.
and I should append $ADMINEMAIL$ as follows in service command definition.
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nHostname: $HOSTNAME$\nAddress: $HOSTADDRESS$\nResolver Group: $_SERVICERESOLVER_GROUP$\nService Notes: $SERVICENOTESURL$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTNAME$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$ -r $ADMINEMAIL$
correct me if I am wrong.
cdienger
Post by cdienger »
Yes, I believe that should do the trick. From the manual page for the mail command:
-r address
Sets the From address. Overrides any from variable specified in
environment or startup files. Tilde escapes are disabled. The
-r address options are passed to the mail transfer agent unless
SMTP is used. This option exists for compatibility only; it is
recommended to set the from variable directly instead.
Pratapa
Post by Pratapa »
This did not work.
