Mass Acknowledge page lists everything...
tbarnett
Post by tbarnett »
Before 5.7.0 the Mass acknowledge page presented me with services and hosts with problems. Now it appears to present everything, that is working and not working. I have to scroll through hundreds of devices to find things that have problems that I wan to acknowledge. Can this behavior be set back tot he previous way? thx
Tom Barnett
Senior Systems Administrator
Prime, inc.
2740 N. Mayfair Ave
Springfield, MO 65803
benjaminsmith
Re: Mass Acknowledge page lists everything...
Post by benjaminsmith »
Hi Tom,
Thanks for letting reporting the error you're experiencing. Can you post a screenshot for us? I would like to make sure the behavior you are experiencing matches what I've got on my test system.
Benjamin
tbarnett
Post by tbarnett »
I have attached a shot of what comes up first..
then another shot of a device that needs to be acknowledged.
Before the current version devices not requiring an acknowledgement did not show up on this page.
Tom
Tom Barnett
Prime, inc.
2740 N. Mayfair Ave
The issue will be fixed in Nagios XI 5.7.2.
If you wanted to fix this sooner, you could try the following:
1. Make a back of the "queries.inc.php" file:
cp -p /usr/local/nagiosxi/html/db/queries.inc.php /usr/local/nagiosxi/html/db/queries.inc.php.backup
2. Download the zip file below:
queries.inc.php.zip
3. Unzip the file and place the patched "queries.inc.php" file into the "/usr/local/nagiosxi/html/db" directory, replacing the original one. Make sure the permissions on the new file are the same as the ones of the backup file (queries.inc.php.backup).
Let us know if this helped.
tbarnett
Post by tbarnett »
That fixed the problem. thanks for your help.
Tom
Tom Barnett
Prime, inc.
2740 N. Mayfair Ave
I am glad I could help! I will be closing this topic now. If you have any further questions/issues, please start a new thread. Thank you!
