NagiosX1 Installation Error
wipro-cloud-services
Post by wipro-cloud-services »
Hi Team,
We’re trying to install Nagios XI on CentOS_6.0_x86_64. Once we run ./fullinstall it’s ending with error message.
Please refer to the attached install.log and guide us for successful installation
Please guide ASAP
Regards,
CCS Team
agriffin
Re: NagiosX1 Installation Error
Post by agriffin »
There seems to be a conflict between two different versions of python 2.6.5. However, the latest version of python available in the repos is 2.6.6. Try updating your system and then installing Nagios XI again:
# yum update
It failed to complete the process when we run "yum update"
Please refer to the below result and suggest ASAP.
[root@ip-10-194-150-16 ~]# yum update
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Could not get metalink https://mirrors.fedoraproject.org/metalink?repo=epel-6&ar        ch=x86_64 error was
12: Timeout on https://mirrors.fedoraproject.org/metalink?repo=epel-6&arch=x86_6        4: (28, 'connect() timed out!')
 * base: anorien.csc.warwick.ac.uk
 * epel: be.mirror.eurid.eu
 * extras: anorien.csc.warwick.ac.uk
 * ius: download.srv.ro
 * rpmforge: apt.sw.be
 * updates: centos.mirror.serverbeheren.nl
base                                                     | 3.7 kB     00:00
cr                                                       | 3.0 kB     00:00
extras                                                   | 3.0 kB     00:00
ius                                                      | 2.2 kB     00:00
rpmforge                                                 | 1.9 kB     00:00
updates                                                  | 3.5 kB     00:00
updates/primary_db                                       | 3.5 MB     00:04
Setting up Update Process
Resolving Dependencies
--> Running transaction check
---> Package at.x86_64 0:3.1.10-43.el6_2.1 set to be updated
---> Package bash.x86_64 0:4.1.2-9.el6_2 set to be updated
---> Package bind-libs.x86_64 32:9.7.3-8.P3.el6_2.2 set to be updated
---> Package bind-utils.x86_64 32:9.7.3-8.P3.el6_2.2 set to be updated
---> Package chkconfig.x86_64 0:1.3.49.3-1.el6_2 set to be updated
---> Package cups-libs.x86_64 1:1.4.2-44.el6_2.3 set to be updated
---> Package curl.x86_64 0:7.19.7-26.el6_2.4 set to be updated
---> Package cvs.x86_64 0:1.11.23-11.el6_2.1 set to be updated
---> Package device-mapper-multipath.x86_64 0:0.4.9-46.el6_2.2 set to be updated
---> Package device-mapper-multipath-libs.x86_64 0:0.4.9-46.el6_2.2 set to be up        dated
---> Package dhclient.x86_64 12:4.1.1-25.P1.el6_2.1 set to be updated
--> Processing Dependency: dhcp-common = 12:4.1.1-25.P1.el6_2.1 for package: 12:        dhclient-4.1.1-25.P1.el6_2.1.x86_64
---> Package dracut.noarch 0:004-256.el6_2.1 set to be updated
---> Package dracut-kernel.noarch 0:004-256.el6_2.1 set to be updated
---> Package freetype.x86_64 0:2.3.11-6.el6_2.9 set to be updated
---> Package glibc.i686 0:2.12-1.47.el6_2.12 set to be updated
---> Package glibc.x86_64 0:2.12-1.47.el6_2.12 set to be updated
---> Package glibc-common.x86_64 0:2.12-1.47.el6_2.12 set to be updated
---> Package glibc-devel.x86_64 0:2.12-1.47.el6_2.12 set to be updated
---> Package glibc-headers.x86_64 0:2.12-1.47.el6_2.12 set to be updated
---> Package gmp.x86_64 0:4.3.1-7.el6_2.2 set to be updated
---> Package gnutls.x86_64 0:2.8.5-4.el6_2.2 set to be updated
---> Package initscripts.x86_64 0:9.03.27-1.el6.centos.1 set to be updated
---> Package iptables.x86_64 0:1.4.7-5.1.el6_2 set to be updated
---> Package ius-release.noarch 0:1.0-10.ius.el6 set to be updated
---> Package jasper-libs.x86_64 0:1.900.1-15.el6_1.1 set to be updated
---> Package kernel.x86_64 0:2.6.32-220.17.1.el6 set to be installed
---> Package kernel-devel.x86_64 0:2.6.32-220.17.1.el6 set to be installed
---> Package kernel-firmware.noarch 0:2.6.32-220.17.1.el6 set to be updated
---> Package kernel-headers.x86_64 0:2.6.32-220.17.1.el6 set to be updated
---> Package kpartx.x86_64 0:0.4.9-46.el6_2.2 set to be updated
---> Package krb5-libs.x86_64 0:1.9-22.el6_2.1 set to be updated
---> Package libcurl.x86_64 0:7.19.7-26.el6_2.4 set to be updated
---> Package libgcrypt.x86_64 0:1.4.5-9.el6_2.2 set to be updated
---> Package libpng.x86_64 2:1.2.49-1.el6_2 set to be updated
---> Package libssh2.x86_64 0:1.2.2-7.el6_2.3 set to be updated
---> Package libtasn1.x86_64 0:2.3-3.el6_2.1 set to be updated
---> Package libtiff.x86_64 0:3.9.4-5.el6_2 set to be updated
---> Package libxml2.x86_64 0:2.7.6-4.el6_2.4 set to be updated
---> Package libxml2-python.x86_64 0:2.7.6-4.el6_2.4 set to be updated
---> Package module-init-tools.x86_64 0:3.9-19.el6_2 set to be updated
---> Package mysql-libs.x86_64 0:5.1.61-1.el6_2.1 set to be updated
---> Package net-tools.x86_64 0:1.60-110.el6_2 set to be updated
---> Package nspr.x86_64 0:4.8.9-3.el6_2 set to be updated
---> Package nss.x86_64 0:3.13.1-7.el6_2 set to be updated
--> Processing Dependency: nss-softokn(x86-64) >= 3.12.9 for package: nss-3.13.1        -7.el6_2.x86_64
---> Package nss-sysinit.x86_64 0:3.13.1-7.el6_2 set to be updated
---> Package nss-util.x86_64 0:3.13.1-3.el6_2 set to be updated
---> Package openssh.x86_64 0:5.3p1-70.el6_2.2 set to be updated
---> Package openssh-askpass.x86_64 0:5.3p1-70.el6_2.2 set to be updated
---> Package openssh-clients.x86_64 0:5.3p1-70.el6_2.2 set to be updated
---> Package openssh-server.x86_64 0:5.3p1-70.el6_2.2 set to be updated
---> Package openssl.x86_64 0:1.0.0-20.el6_2.4 set to be updated
---> Package pam.x86_64 0:1.1.1-10.el6_2.1 set to be updated
---> Package pango.x86_64 0:1.28.1-3.el6_0.5.1.centos set to be updated
---> Package passwd.x86_64 0:0.77-4.el6_2.2 set to be updated
---> Package rpm.x86_64 0:4.8.0-19.el6_2.1 set to be updated
---> Package rpm-build.x86_64 0:4.8.0-19.el6_2.1 set to be updated
--> Processing Dependency: /usr/bin/gdb-add-index for package: rpm-build-4.8.0-1        9.el6_2.1.x86_64
---> Package rpm-libs.x86_64 0:4.8.0-19.el6_2.1 set to be updated
---> Package rpm-python.x86_64 0:4.8.0-19.el6_2.1 set to be updated
---> Package ruby.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package ruby-devel.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package ruby-docs.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package ruby-irb.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package ruby-libs.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package ruby-rdoc.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package ruby-ri.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package ruby-tcltk.x86_64 0:1.8.7.352-7.el6_2 set to be updated
---> Package tzdata.noarch 0:2012c-1.el6 set to be updated
---> Package yum.noarch 0:3.2.29-22.el6.centos.2 set to be updated
---> Package dhcp-common.x86_64 12:4.1.1-25.P1.el6_2.1 set to be updated
Error: Package: nss-3.13.1-7.el6_2.x86_64 (updates)
           Requires: nss-softokn(x86-64) >= 3.12.9
           Installed: nss-softokn-3.12.8-1.el6_0.x86_64 (@updates)
               nss-softokn(x86-64) = 3.12.8-1.el6_0
           Available: nss-softokn-3.12.7-1.1.el6.x86_64 (base)
               nss-softokn(x86-64) = 3.12.7-1.1.el6
Error: Package: rpm-build-4.8.0-19.el6_2.1.x86_64 (updates)
           Requires: /usr/bin/gdb-add-index
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
mguthrie
Post by mguthrie »
Lets try removing python altogether, and then rerunning the installer. It seems like it's conflicted with a python package from a different repo.
yum remove -y python python-devel
Was this a fresh install of CentOS 6?
Yes. This is a fresh install.
Please do contact us on +91-9980633622 to progress it faster.
Thanks.
Hi Team,
It failed to work even after Python remove & re-install.
Thanks.
wipro-cloud-services wrote:Hi,
I have to ask, was it directly fresh, or is this a default custom corporate build?
Hi ,
I am trying to install Nagios in Linux machine by issuing the below command
wget http://assets.nagios.com/downloads/nagiosxi/xi-lat
--2012-05-29 07:46:00-- http://assets.nagios.com/downloads/nagiosxi/xi-latest-d
Connecting to 145.26.81.171:8080... connected.
Proxy request sent, awaiting response... 404 Not Found
2012-05-29 07:46:00 ERROR 404: Not Found.
we are trying to install this as per clinet requirement . This is the urgent issue . Please guide ASAP .
Regards,
Renuka
Hi Any body is theree to reply.
We need to install Nagios on CentoS 6 and Amanda . Please guide ASAP . it is urgent requirement
Regards,
Renuka
Try starting with
wget http://assets.nagios.com/downloads/nagiosxi/xi-latest.tar.gz
It looks like you were missing part of the file name
